Export 3D plots in GIZMO
ldaglio
I am trying to export the #D scatter plot I generate in GIZMO as EPS and PCT. However, when I open it in Adobe illustrator does not take it as a vector map. Adobe reads it as an image, which I am unable to transform or edit. DO you know other trick to save the graph?
Thank you so much
Liza
If you need to export Gizmo images set the output resolution to a sufficiently high factor and export a bitmap image. For example, you can execute:
ModifyGizmo outputResFactor=4
Now export a regular bitmap image and you will get a 4x screen resolution.
May 6, 2015 at 08:32 am - Permalink
