Two indented loops
duncan86
I have a problem during the developing of a function for Igor. A couple of weeks ago, I had a very useful tip from John Weeks, how to make a for loop in a user defined function. This function essentially creates a certain number of gaussian peaks defined through the variable "points", shifted by the values contained in the wave "BEs" and multiplied by the values contained in the wave "exp_dump". Now, I'm trying to edit this function introducing a higher level of complexity. As you can see below, I would like to create, with this new modified function, the same set of data but using several different waves for the "exp_dump", since every single "exp_dump" wave contains a different decay mode. In few words, I want to replicate the same calculation contained in the old function but using different waves for the "exp_dump". In principle, I could do this manually, but the problem is that the "exp_dump" waves are provided by the our experimental equipment, and the number of these waves are so high that I really need for a code......For sake of clarity, I have reported below both the old core and the new function that I'm trying to develop.
Many thanks for your support,
Duncan
//"OLD FUNCTION" Function simulation(points,FWHM,V_index,theta) variable points variable FWHM variable V_index variable theta variable i string N1s_peak_ WAVE BEs WAVE BE_scale WAVE exp_dump for (i = 0; i<points; i+=1) //Here I simply create the different gaussian peaks dumped by the values contained in the exp_dump wave..... N1s_peak_ = "N1s_peak_" + num2str(i) Make/O/N=161 $N1s_peak_/WAVE=wout Variable x0 = BEs[i] Variable x1 = exp_dump[i] wout = x1*(0.0355 + 0.95*((V_index)*(exp(-((BE_scale - x0)/(0.525*(FWHM)))^2)) endfor //"NEW FUNCTION" ....... variable q //this will be the index over the different "exp_dump_" waves coming out for the experiment variable i string N1s_peak_ WAVE BEs WAVE BE_scale WAVE $exp_dump_ //I guess this is also not the way to use $ in a UDF..... for (q = 0; q<lambda_points; q+=1) // I would like to use something like this..... Variable x3 = $exp_dump_ // I don't know how to implement this one. I was thinking to two co-indented for loops...... for (i = 0; i<points; i+=1) N1s_peak_ = "N1s_peak_" + num2str(i) Make/O/N=161 $N1s_peak_/WAVE=wout Variable x1 = BEs[i] Variable x2 = exp_dump[i] wout = x2*(0.0355 + 0.95*((V_index)*(exp(-((BE_scale - x1)/(0.525*(FWHM)))^2)) // Here I don't know how to introduce the second dependency, with q that varies over the different "exp_dump" waves...... endfor endfor
Wave w = $("exp_dump_" + num2str(j))
; just as you do for the output wout.Modify your new code like this:
Also note that you should avoid using "q" as loop index because it is a built in function in Igor.
April 24, 2015 at 12:23 pm - Permalink
Again, thanks a lot for your support! It was extremely helpful!
Duncan
April 24, 2015 at 10:58 am - Permalink
I'm back with a problem. Here is the code on which I'm working on:
So, in the second for loop within the primary one I want to make a summation of the waves previously generated by the first indented for loop (i.e. "N1s_peak_"). The function runs with no problems but, when I go to the results, in the "summation" waves (correctly indexed by j) I find that all the 161 values are zero. Where do I make a mistake? Could somebody help me?
Many thanks in advance for your help,
Duncan
April 24, 2015 at 04:12 pm - Permalink
Once that works, put it in a for-loop ...
Build your code this way. You can debug it a lot easier (and we can read it better to help you).
April 30, 2015 at 02:59 pm - Permalink
This is a really good tip! Thanks!
Duncan
May 4, 2015 at 11:10 am - Permalink
