Transparency on Fill to Zero etc
Hi.
I really like the ability to make fill pattern backgrounds transparent. Would it be possible to set solid, 25%, 50% fill colours etc with transparency to allow you to partly see though fills with constant fill and no pattern? I assume you would have a user defined alpha for each trace to due this.
This would really help make nicer plots.
Jonny
This will be in the next major release.
However, due to a complete replacement of the base code, (with Qt) this will not be available soon.
