So from a mathematical/physical point of view what I'm trying to do is convert a potential diagonal in position space to momentum-space. V(x) is a wave I have. The space I've defined is in units of micrometers and Hz. I essentially need a 2d wave that is functionally a 3d wave integrated along one dimensio (the x dimension). This is not tenable when I've got a 100 micron wide area and a 100 nm resolution defining the size of my eigensystem (and is barely tenable with just a 2d wave). So I tried integrating inside the 2d wave. Igor freaks out. Igor will do all sorts of mathematical operations inside a wave like this with explicit indexing, but integration doesn't seem to be on the list. Does anyone have a tenable idea in how I can make this work?
I'm aware at this point I was using integrate1D entirely incorrectly, but my problem still stands. How do I generate a multidimensional wave that is in part the sum of an integral? So M[][] = y(p,q) + Int f(p,q,x)dx. I get the feeling this is a solved problem because it's so easy in other scripting languages.
It may be easy but the devil is in the details. This is an interesting application -- we will help you with implementation details via technical support (support@wavemetrics.com).
March 31, 2015 at 12:14 pm - Permalink
March 31, 2015 at 03:06 pm - Permalink
April 1, 2015 at 12:43 pm - Permalink
April 2, 2015 at 09:37 am - Permalink
There was one (very tiny) NaN in an input wave.
April 2, 2015 at 03:16 pm - Permalink
