Removing Igor Pro 6.0.x
warakurna
Igor Pro 6.1 is out and it is recommended to remove version 6.0.x before installing the new version. Unfortunately I do not find any uninstall option in the windows software dialog window and nothing in the Igor Pro Folder. I'm afraid that during one of the last minor updates the uninstall option have been removed automatically.
How can I remove Igor Pro in a clean way from my windows system before installing the new version?
Thanks in advance...
In your case, remove the Igor Pro Folder manually and then merge the uninstallAll3x4x5x6xIgorKeys.reg.
Obviously, you'd need to keep that file around (on your desktop, perhaps) BEFORE deleting your Igor Pro Folder.
June 28, 2009 at 10:43 am - Permalink
I simply re-installed Igor 6.05 over the existing install. The missing uninstall link and the unvise.exe was back. Then I was able to uninstall in a clean way and installed the new 6.1...
July 6, 2009 at 04:07 am - Permalink
