Curve fit: "No constraints active or violated"
mailfert
Fit converged properly
--Curve fit with constraints--
<b>No constraints active or violated<b>
<pre><code class="language-igor">
Thanks for your help.
Sébastien
Sébastien
There is one case in which you might do a fit with constraints without knowing that you did it: the Gauss2D built-in fit function applies a constraint to the "cor" coefficient to keep it within the -1 to 1 range for which it is defined.
March 18, 2015 at 09:40 am - Permalink
March 18, 2015 at 09:54 am - Permalink
Yes indeed- what I said was a very long way to say that the fit worked :)
March 18, 2015 at 10:01 am - Permalink
