Rotate Gizmo ticks and tick labels
masheroz
How can I rotate the ticks and tick labels so they can be seen?
As far as I can see, altering the rotation parameters in Axis Stuff->Ticks and numerical labels doesn't do anything.
Any ideas?
I'm using Igor Pro v6.3.6.4.
You are not telling us what you tried so I'll skip directly to the correct approach. You can accomplish the following from the Axes dialog. I will use commands to simply the explanation.
1. Turn off z-axis labeling because they become irrelevant in this view.
2. Add an offset so that the labels are drawn outside the box boundaries not below them. For example
3. Choose rotation axis and rotation angle. For the x-direction labels I use
I hope this helps,
March 16, 2015 at 01:16 pm - Permalink
It seems that "1" nominates the axis, and "rotation (degrees)" is actually the way that it works.
I got it, but with an offset of +0.1 and a rotation of -90 for the X axis.
Now to investigate how to rotate the ticks.
March 16, 2015 at 08:10 pm - Permalink
There is no user-control over the rotation of the tickmarks.
Out of curiosity: your display is equivalent to that of a regular image. Why use Gizmo when you completely suppress the third dimension?
March 17, 2015 at 09:59 am - Permalink
I then want to have a single image showing the dataset from the top. Why do I have to go to the trouble of making a new image, redoing the colour scheme, rescaling the axes, and everything else that I've done to get the gizmo plot just right when I can just rotate the gizmo plot to view from the top.
March 17, 2015 at 06:19 pm - Permalink
You do not have to create a new image but if you did, the resulting labels would look much better especially if the image is exported. Gizmo's output is a bitmap and that includes any labels.
March 18, 2015 at 12:06 pm - Permalink
