If you are going to work with images you might benefit from reading the Image Processing Tutorial. You can find it under File Menu->Example Experiments->Tutorials.
In general 2D convolutions and correlations are computed using FFT/IFFT. Radial averaging can be computed the hard way (direct pixel averaging of the autocorrelation) or using ImageLineProfile with a radial path and non-zero width.
February 27, 2015 at 07:20 am - Permalink
