National Instruments TDM and TDMS files
hrodstein
I confess that I am largely ignorant about these formats. Quickly reading some of the National Instruments web pages, it seems like this is something Igor should support. However because of time constraints and competing priorities, I can't say when or if we will get to it.
In the mean time, a user-created XOP might be a good idea.
I plan to read up on TDM and TDMS over the next few days to be better able to answer questions about it.
I've created this forum topic in case others want to discuss it.
My first glance here shows that TDM is an XML format. For a first step, the XML file loader I have written here, in conjunction with a suitable XSL file, might work without needing to do XOP programming.
January 27, 2009 at 03:32 pm - Permalink
January 27, 2009 at 04:03 pm - Permalink
January 27, 2009 at 04:06 pm - Permalink
The TDM license has some obnoxious provisions.
January 27, 2009 at 04:22 pm - Permalink
Does having a .dll mean, writing a TDM/TDMS loader/generator procedure/XOP is out of the question for Mac OS? Or does it mean, we just have to work a bit harder at it?
(not that I am intending to write something, just that I was struck with the question as a preface)
January 28, 2009 at 09:09 am - Permalink
It means that you would have to reverse engineer the file format to support Macintosh and that your version would be out-of-date whenever NI adds a new variant.
It seems that they should provide a Macintosh DLL, and Linux too.
January 28, 2009 at 07:34 pm - Permalink
Thanks
Caroline Tipton
Data Management Manager
June 8, 2009 at 01:31 pm - Permalink
Caroline - I did write a TDMS plug-in for Igor on Windows. It will be part of the soon-to-be-released Igor Pro 6.1 installation and is available in the 6.1 beta now.
I had an email exchange with Caroline Bright (you?) about it in February.
June 8, 2009 at 10:39 pm - Permalink
I recorded some data in SignalExpress 3.0, installed the TDM.xop, Igor 6.1 and tried uploading the file into IGOR but got the following error/output:
Loading "Voltage.tdms" from "F:UCLA Programming:TDMS Conveter:Sample Data:"
Created root:Voltage
Numeric variable datetime renamed to datetime0 because of a name conflict.
Numeric variable DateTime renamed to DateTime0 because of a name conflict.
DIAdem library error from routine during TDMLoadData: An invalid argument was passed to the library.
-Max
June 23, 2009 at 02:52 pm - Permalink
I do really like the ability of loading in TDM-files to Igor. However, loading the TDM into igor discards the wave properties, i.e x-scaling and x-unit, of the TDM-channel. Instead the channel becomes just an array of numbers, with a note containing the scaling factors.
Is there a easy way of adding a property to the labview generated file so that the TDMloadData treat the channel as a wave and not an array?
Or better, could the TDMloadData be updated so that the properties; "wf_xname", "wf_xunit_string", "wf_increment" ..., are mapped onto the igor wave so that the right x-unit and scaling are preserved?
Regards
Gustav
December 16, 2009 at 02:21 am - Permalink
My understanding is that any other channel properties are user-defined. I'm not aware of any established conventions such as "wf_increment". At least none were mentioned in the NI documentation when I wrote TDMLoadData.
The TDM XOP loads user-defined properties into the wave note. The TDM Help file explains how to extract the user-defined properties from the wave note and use them for whatever purpose. To see this, execute:
DisplayHelpTopic "TDMLoadData"
and read the section entitled "Channel Properties".
Using the technique explained there, you should be able to do what you want.
December 16, 2009 at 03:52 pm - Permalink
By convention, LabVIEW defines the wf_start_time, wf_start_offset, wf_increment and wf_samples properties.
I have made a note to support this in the TDM XOP but I can't say when I will get to it.
December 16, 2009 at 04:22 pm - Permalink
It is a fantastic file format.
I have many other collaborators using this format as well and I always have them refer to this tread for installation tips.
Unfortunately, the dll link provided earlier has ceased to exist.
The site that hosts the link is available:
http://digital.ni.com/public.nsf/allkb/A3663DE39D6A2C5A86257204005C11CA
but the ability to access the dll is not accessible:
http://research.ni.com/run/2007codelicenseagree
Is there any support from Wavemetrics in this regard, or do I need to keep bugging NI?
Any plans to build this into Igor as a standard feature?
January 13, 2016 at 03:17 pm - Permalink
I'm surprised it lasted this long. Note the "research" part of the link.
You can find the required libraries by going to http://www.ni.com/white-paper/3727/en/ and clicking the c_dll_tdm.zip file in the Downloads section in the top/right part of that web page.
For Igor7, I have updated the TDM help file with this new link and also added a 64-bit version of the XOP.
We will support it as long as NI provides the required support. Third-party access to TDM files seems to be a step-child project at NI, based on the lack of a real installer.
No. You can see from the TDM XOP installation instructions that it requires a grab bag of third-party libraries. We would have to ship all of that junk with every copy of Igor.
January 13, 2016 at 04:35 pm - Permalink
Dear All,
Are there some updates regarding loading TDMS-Files?
I copied the 64 bit XOP into the folder Igor-Extension (64-Bit) and also installed NI-Diadem 2021. Is there something else I should do?
But I get this error message:
I'm using Igor-Pro 9 Beta Version 9.0.0.8 Build 37752
Thank you for your help
August 3, 2021 at 01:09 am - Permalink
In reply to Dear All, Are there someā¦ by LausX
Problem solved.
Thanks
August 3, 2021 at 01:29 am - Permalink
@LausX: Any insight when solving the problem which you like to share?
August 3, 2021 at 09:31 am - Permalink
I was getting the exact same error message as LausX and I fixed the problem by doing steps 1-3 in "Installing the 64-bit Version of the TDM XOP" found in the Igor help file "TDM Help.ihf". Maybe that will help!
January 26, 2022 at 10:42 am - Permalink
