Using dimension labels programmatically / dynamically in a loop
Is there any way to use dimension labels in a programmatic or dynamic way?
For example, I want to do
// ... variable i=0 do string thisLabel = stringFromList(i, listOfLabels) labelledWave[%thisLabel] i += 1 while (i < 10)
... but this considers 'thisLabel' as the label. Adding $ or similar didn't work for me. Thanks in advance.
(The % needs to be between the [ ], not within the string thisLabel)
January 21, 2015 at 05:16 am - Permalink
HJ
January 21, 2015 at 05:25 am - Permalink
http://www.igorexchange.com/node/6249
EDIT
Oh, I think I misunderstood the question, which doesn't seem to be about labeling, but rather using them….
January 21, 2015 at 06:10 am - Permalink
