Linear Correlation
Fab18
Where I can put the data, for example considering the data in 2 waves (data1, data2) to do a linear correlation executing the command: StatsLinearCorrelationTest/T=1/Q data1,data2; there a example in Igor, but in the example ends showing me a result table (good) from a strange kind of "screen notebook" that I can't put anything inside (the data in two waves) to then execute it with the command and show the much desired results table, so, where I can put the data in two waves to show the table results? Sorry, I'm a sort of noob. Thanks in advance.
Fabricio
It appears that you need to develop basic familiarity with IGOR before you jump into statistical calculations. I recommend that you take the time to go through the introduction tutorial. You will find it by selecting from Windows Menu -> Help Windows -> Getting Started.ihf.
After you go through that tutorial you should be able to execute StatsLinearCorrelationTest on your data.
January 6, 2015 at 10:47 am - Permalink
