XOP free wave question
gregorK
I am writing a XOP operation where I would like to create a temporary (i.e. free) WAVE which needs to be accessible from the calling user function in IGOR. It should work similar to local variables/strings but for WAVEs. Can somebody point me to the right direction how to proceed?
I already tried creating a free wave using MDMakeWave and the dataFolderHandle input parameter set to -1, but then I cannot access this free wave from inside the user function which called this custom XOP operation (I guess the free wave is killed after the operation finishes and thus never gets to the calling function in IGOR) ...
Thank you for your help!
Gregor
The only way to pass a wave handle from an external operation back to the calling user-defined function is through a waveHndl field in a structure.
You need to declare a structure parameter in your operation template. You then need to define a structure in the procedure file, create an instance of it in the user-defined function, and pass the structure to the external operation as a parameter.
The external operation must set the waveHndl field in the structure and call HoldWave on it. When the external operation returns to the user-defined function, the function can access the wave through the waveHndl field.
When the function terminates, the instance of the structure goes out of scope and the wave referenced by the waveHndl field, if it is a free wave, should be automatically killed.
To learn about structures in procedures, execute:
DisplayHelpTopic "Structures In Functions"
To learn about structure parameters in external operations, see Structure Parameters in Chapter 5 of the XOP Toolkit manual.
A simpler alternative is to create a global (not free) wave in the current data folder with a specific wave name and have the user-defined function access it through a wave reference variable and then explicitly kill it.
December 25, 2014 at 11:58 pm - Permalink
For details, see DataFolderAndName Parameters in Chapter 5 of the XOP Toolkit manual. The subsection DataFolderAndName Destination Wave Example shows how to handle /DEST but does not include the code for creating a free wave. To create a free wave, add the /FREE flag and, if it is present, add the kOpDestWaveMakeFreeWave constant to the options variable before calling GetOperationDestWave.
December 26, 2014 at 05:34 am - Permalink
Gregor
Gregor Kladnik
ALOISA beamline @ Elettra synchrotron
December 26, 2014 at 07:08 am - Permalink
