Resampling times series to the same integer timebase
Hello, I am new to Igor and wondered if anyone could help, I have searched the forum but not quite finding the answer I need
I am working with time series: the measurements are made at different times of calendar years and are unevenly spaced. The Y values are decimal years (2004.3, 2004.7, 2005.1, 2005.4 etc)
I want to resample each time series by fitting a best fit spline and then interpolate the spline value for the top of the year i.e. obtain a series of Y values for the integer X value such that all my data series are scaled to the same timebase.
I would be very grateful for any guidance!
Thanks in advance and apologies if this has been covered before....
dave
Quote:
I am new to Igor
If you have not already done it, do the first half of the Igor guided tour. It is essential. Choose Help->Getting Started.
I don't really understand the question but it might be helpful if you execute this command and read the help topic that it displays:
DisplayHelpTopic "Waveform Versus XY Data"
hrodstein: thank you! I had done the tours etc but didn't appreciate that converting XY data to a waveform did what I was looking for! The link was very helpful.
Thanks again, dave
