Adding or moving a column among other ones in a table
as in the subject, I haven't found a way to add a column between two already created, or how to shift/drag one column in my table.
Wouldn't that be just a "cosmetic" effect? Is it instead a critical action for Igor?
You can drag a column by pressing the option (Macintosh) or Alt (Windows) key and dragging the column header.
For other table-related shortcuts, choose Help->Shortcuts.
Thank you so much, I had been looking for it so long (Help, Google...).
