out of stack space when using slider
serrano02
I've run into a problem with a data analysis interface where I sometimes (by that I mean it's hard to reproduce consistently) get an "out of stack space (too much function or macro recursion)" error.
The idea of the interface is: Dragging a slider updates the presented data, where "updating" means look up data from an image stack, process, and display. The process part can be rather time-consuming, i.e. a few hundred milliseconds.
Here's some code to illustrate:
#pragma rtGlobals=3 // Use modern global access method and strict wave access.
//EXECUTE THIS TO SHOW THE DEMO
Function start()
//---generate dummy data
Make/O/N=(100,100,500) images
Setscale/I z, 0, 65535, images
images[][][] = z
//---extract the first frame
ImageTransform/P=0 getplane images
Wave m_imageplane
Duplicate/O m_imageplane, currentframe
//---display
showimage()
Function showimage()
Wave images
DoWindow/F win
if(!v_flag) //--- create window if it doesn't exist
Wave currentframe
NewImage/N=win currentframe
ModifyImage/W=win currentframe ctab= {0,65535,Grays,0}
Controlbar 50
Slider sldFrame,pos={1,1},size={220,45},limits={0,499,1},value= 0,vert= 0,proc=sliderproc
else //--- update frame
//Here I want do do image processing which might be rather lengthy
//In place of calculations, I sleep
sleep/T 20
Controlinfo/W=win sldFrame
ImageTransform/P=(v_value) getplane images
Wave m_imageplane
Function SliderProc(name, value, event) : SliderControl
String name
Variable value
Variable event // bit field: bit 0: value set; 1: mouse down,
// 2: mouse up, 3: mouse moved
NVAR/Z UPDATING_FRAME
if(!NVAR_EXISTS(UPDATING_FRAME))
Variable/G UPDATING_FRAME = 0
if(UPDATING_FRAME==1)
UPDATING_FRAME=1
if(event %& 3)
showimage()
UPDATING_FRAME=0
Function start()
images[][][] = z
Wave m_imageplane
//---display
showimage()
Wave images
DoWindow/F win
Wave currentframe
Controlbar 50
sleep/T 20
Wave m_imageplane
String name
Variable value
UPDATING_FRAME=1
if(event %& 3)
showimage()
UPDATING_FRAME=0
Now, when I drag the slider around for a long time (say, over 30 seconds), I suddenly end up with >20 pop up windows "out of stack space" that all appear at the same time, and I've had a hard time to fix it. Some try-catch sprinkled in on various places didn't do anything to help (although admittedly, I didn't really know what I was doing there).
Without knowing anything about the internals, I'm guessing that the event-handler for the slider puts a new instance of SliderProc in the queue every time something happens to the slider. If
SliderProc
doesn't finish quickly enough, I get the error. The whole business of UPDATING_FRAME
in the code was supposed to get out of the function as quickly as possible, if another instance is updating already, to keep the queue clear.Anyway, help is greatly appreciated.
The easiest solution is to switch to structure based GUI procedures and use blockReentry = 1, see
DisplayHelpTopic "Control Structure blockReentry Field"
.November 28, 2014 at 08:22 am - Permalink
November 28, 2014 at 11:33 am - Permalink
December 1, 2014 at 10:53 am - Permalink
