Save waves from graph
Is there an easy way to save the all the waves from an already made graph in one separate text file?
T
Select your graph. Data>Save Waves... then check From Target. Only waves in the graph appear in the list. Select the ones you want and save.
That was clear to me. The only problem is that if you have a multitude of folders in your data folder and the waves in the graph coming from this folders, it make it a bit difficult to dig in each folder and choose the proper wave to save. I thought there is another faster way to do that.
T
I see. Sorry for the basic answer. Maybe somebody else will be along with a better answer.
You could use File->Save Graph Copy. That will save a new Igor experiment file with copies of all the waves required to make the graph, as well as the graph itself. Sounds like you don't really need the graph, just the waves, but that shouldn't be a big problem.
