Customized data import
Would add that it is really unfortunate that choosing 'data/load waves/load general text' does not include the 2D option (?!). Also some ability to tell Igor where to start numbering sequential files would be nice, I ended up writing a little script to rename everything (z_0 -> z_1) so that the file numbers matched the z. I imagine there is probably an easier way tho?
Anyhow, here is what the .dat file looks like, the exact format is not important regarding how the waves are saved, just need to see how to extract all the data in any fashion, if its possible. Thanks.
Z= 1, chisq= 0.170190
3.55221981e-002 2.25354459e-001 2.62782423e-002 2.25354636e-001
3.52695173e-002 2.25355749e-001 6.77755867e-002 4.38850114e+000
3.56601775e-003 4.03881150e-001 2.76131055e-002 1.44488619e+000
Z= 2, chisq= 0.013113
3.73696013e-002 5.36479656e-001 3.60228922e-002 5.36480729e-001
1.22544155e-001 5.36493547e-001 5.06400486e-003 2.70930915e-001
2.03620941e-002 8.51962305e-001 2.74236552e-002 2.33542971e+000
Z= 3, chisq= 0.258875
1.07960369e-001 9.23258728e-001 1.06777482e-001 9.23233431e-001
7.71392003e-002 4.74123946e-002 2.75244208e-003 1.69761557e-001
1.08034077e+000 1.90675572e+001 3.46769903e-001 6.28398894e+000
Oh and I have a problem with rounding as well, 3.56601775e-003 becomes 0.00356602 (i clicked double precision), is it possible not to round here?
Here is a quick and dirty piece of code that you can start with:
Hope this helps,
Kurt
September 23, 2014 at 03:14 am - Permalink
September 23, 2014 at 03:20 am - Permalink
That's just the display in the table. Right-click on the column and select Digits-> [something bigger than 6]
September 23, 2014 at 10:34 am - Permalink
