Igor does not look at the units and try to interpret them. It just takes them as they are so the results will 'pA'*'ms' where I used single quotes to emphasize they are just two letters and have no other meaning. Had you used A and s as units with the values scaled to pico and milli, then the results would be in A*s with a exponent in the vicinity of 10^-16. For example:
•SetScale y,0,0,"A", ydata
•SetScale/I x,0,1e-3,"s",ydata
•display ydata
•print area(ydata)
5e-16
Note that the axes will be properly labeled in pA and ms.
The units for the area printout are A*s.
Larry Hutchinson
WaveMetrics
support@WaveMetrics.com
August 29, 2014 at 01:26 pm - Permalink
