Need Very Fast Range-within-Waves Extraction Algorithm, My Two Solutions Are Too Slow
astrostu
Problem: I have code that zooms to the next crater in my list to study. Because the actual analysis region for that crater is much smaller than 10°x10°, my code extracts the WAC DTM around the crater and the LOLA point data. The WAC extraction is very fast, taking around 0.3 seconds. The LOLA extraction is MUCH slower, taking over 10 seconds. I can't have a workflow that takes that long to get to the next crater.
Current Code: My current approach is this: The LOLA point data lists are sorted already by latitude. I use FindLevel to location the row of my max and min latitude range that I want to extract, and then I copy those rows to new waves. I then sort by longitude. It's the sorting that takes the longest since sorting is one of the slowest basic things you can do. I then use FindLevel again to get the rows for my min and max longitude, delete the other rows from the temporary waves, and I have my range:
//Extract and set scale. PEDR *MUST* be pre-sorted by Pt_Latitude.
Variable pt_start, pt_end
if((crater_center_long_index-radius_long) >= Pt_Longitude[0])
FindLevel/P/Q Pt_Longitude, (crater_center_long_index-radius_long)
pt_start = V_LevelX
pt_start = 0
if((crater_center_long_index+radius_long) <= Pt_Longitude[numpnts(Pt_Longitude)])
FindLevel/P/Q Pt_Longitude, (crater_center_long_index+radius_long)
pt_end = V_LevelX
pt_end = numpnts(Pt_Longitude)
Duplicate/O/R=[pt_start, pt_end] Pt_Latitude, Pt_Lat_Temp
Duplicate/O/R=[pt_start, pt_end] Pt_Longitude, Pt_Lon_Temp
Duplicate/O/R=[pt_start, pt_end] topography, Pt_Ele_Temp
print (stopMSTimer(-2)-timer_start)*1e-6
Sort Pt_Lat_Temp Pt_Lon_Temp, Pt_Ele_Temp, Pt_Lat_Temp
if((crater_center_lat_index-radius_lat) >= Pt_Lat_Temp[0])
FindLevel/P/Q Pt_Lat_Temp, (crater_center_lat_index-radius_lat)
pt_start = V_LevelX
pt_start = 0
if((crater_center_lat_index+radius_lat) <= Pt_Lat_Temp[numpnts(Pt_Lat_Temp)])
FindLevel/P/Q Pt_Lat_Temp, (crater_center_lat_index+radius_lat)
pt_end = V_LevelX
pt_end = numpnts(Pt_Lat_Temp)
DeletePoints pt_end, (numpnts(Pt_Lat_Temp)-pt_end), Pt_Lat_Temp, Pt_Lon_Temp, Pt_Ele_Temp
DeletePoints 0, pt_start, Pt_Lat_Temp, Pt_Lon_Temp, Pt_Ele_Temp
pt_start = V_LevelX
pt_start = 0
pt_end = V_LevelX
pt_start = V_LevelX
pt_start = 0
pt_end = V_LevelX
Potential Speed-Up: I thought that, perhaps instead of sorting, I could just loop through every point and check to see if it's in my longitude range. Problem is, that takes much longer. The code is the same as above, just change the last block, the one within the timing output:
Variable counter_dummy = 0
do
if(Pt_Lat_Temp[counter_dummy] < (crater_center_lat_index-radius_lat))
DeletePoints (counter_dummy),1, Pt_Lat_Temp, Pt_Lon_Temp, Pt_Ele_Temp
elseif((crater_center_lat_index+radius_lat) > Pt_Lat_Temp[counter_dummy])
counter_dummy += 1
while(counter_dummy < numpnts(Pt_Lat_Temp))
do
counter_dummy += 1
Wave Size: To give you a very, very rough idea of wave sizes, the initial LOLA point list is ~10-11 million. Extracting the longitude range gets me down to around 2 million, so I'm then re-sorting a list of 2M points. When the longitude range is extracted, we're talking about ~200,000 points in the final temporary arrays (I say this is very very rough because it varies depending on LOLA track density and crater size I'm working on). That's why I thought just iterating through the list might be faster, and I expect it would be in a more machine-level language than Igor. But, in Igor, it's not. And yes, this is wrapped in a Function, not a Macro, though the timing is indistinguishable really regardless of it being a Function or a Macro (I tried).
Help?
Rather than FindLevel or iterating through the subset, try Extract.
In fact, it might be faster to use Extract on the original data set rather than making the subset copy.
August 21, 2014 at 11:01 am - Permalink
- Both
FindLevel
calls which search for pt_end don't have to start searching at the 0th point but at the pt_start point, no? See the /R switch ofFindLevel
.- The more fancier
FindLevel
operation supports a /M flag for the number of maximum hits. And I guess you are satisfied with the first hit, no?Btw. as you are working with sorted waves a binary search should be more appropriate than FindLevel.
- All operations involving memory are dead slow as always. So if you can avoid some of the
Duplicate
/DeletePoints
calls things get really much faster. E.g. I don't see that you use the duplicated topography wave.- Have a try with FREE waves for temporary waves
- Replace the two
DeletePoints
calls with one toDuplicate
In case you post a sample experiment, everyone can playaround some more :)
August 21, 2014 at 11:11 am - Permalink
I could modify it to do that, but the FindLevel step takes zero time relative to the Sort line. Like deleting a 33kB Word document instead of the 60GB music folder, I think changing to BinarySearch isn't going to save me time at this point.
Hmmmm... that looks really promising, except that I have 3 waves (lat/lon/ele) and I need to keep the points together (extracting the elevation points corresponding to my lat/lon range). Looking at the documentation for Extract, it doesn't look like I can use it for this kind of problem. FindLevel was useful because it gave me the index range of my data, and I could then extract those rows from each of the three waves. Is there a way to use Extract to be able to do the same kind of thing? If so, that would seem to eliminate the Sort step entirely. Maybe with the /INDX flag?
August 21, 2014 at 11:16 am - Permalink
If I knew the range of the data a priori, I wouldn't need to search through it. Since I don't, and since the LOLA data are not uniform across the lunar surface, I can't assume a range.
Yes. Since it's a sorted list, I just need the first one. I use that to know where the minimum longitude is in my list. Next FindLevel gives me the maximum longitude. Then I extract the data in that range.
The duplicated waves (_Temp) are used in the final display. There's no math in this function that uses it, but it's what's displayed versus the Lat/Lon _Temp and it's what's used in later analysis. Timing test shows the Duplicate lines take ~5% of the time of the function.
Haven't experimented with those before. Useful? Faster? Purpose?
Moot point, see my next post.
Experiment is 400 MB. Don't think I'll be posting it.
August 21, 2014 at 11:40 am - Permalink
Extract/INDX
seems to be much, much faster. Takes about a half second instead of 10 to sort (for this particular dataset). What takes 20% of the time for the code to run now is my do-while loop, see below. I'm guessing there's a much faster Igor-y way to do that step?//Use "Extract" to get the row numbers (index points) of the latitude points in my range,
// storing it to "index_Temp" to use in a moment.
Extract/O/INDX Pt_Lat_Temp,index_Temp, (((crater_center_lat_index-radius_lat) < Pt_Lat_Temp) && (Pt_Lat_Temp < (crater_center_lat_index+radius_lat)))
//Go through with index_Temp and extract the points that I want. Then, delete the remaining
// ones. Yes, I'm over-writing the waves I originally got the data from, but that's okay since
// the number of points MUST be less than the original, and so I am not over-writing points I
// want.
do
Pt_Lat_Temp[counter_dummy] = Pt_Lat_Temp[index_Temp[counter_dummy]]
Pt_Lon_Temp[counter_dummy] = Pt_Lon_Temp[index_Temp[counter_dummy]]
Pt_Ele_Temp[counter_dummy] = Pt_Ele_Temp[index_Temp[counter_dummy]]
counter_dummy += 1
while(counter_dummy < numpnts(index_Temp))
DeletePoints counter_dummy,(numpnts(Pt_Lat_Temp)-counter_dummy), Pt_Lat_Temp,Pt_Lon_Temp,Pt_Ele_Temp
The output from the three print [time] blocks for a few craters of different sizes (and hence different data volumes are, in decreasing order of crater size:
42km crater: 0.6, 3.9, 7.1 sec
5km crater: 0.06, 0.6, 0.8 sec
1km crater: 0.3, 1.0, 1.1 sec
I'm guessing that if I used what both of you recommended - BinarySearch instead of FindLevel - that the 1km analysis would be faster than 5km. I'll try that while I'm waiting for your help on the do-while. :)
August 21, 2014 at 11:49 am - Permalink
Yup. Added print time statements around the first block, finding the longitude range. Times with
FindLevel
:42km crater: 0.05, 0.2, 0.4, 3.7, 6.5 sec
5km crater: 0.0045, 0.07, 0.08, 0.8, 1.0 sec
1km crater: 0.0030, 0.28, 0.3, 1.0, 1.1 sec
Times with
BinarySearch
:42km crater: 0.057, 0.058, 0.3, 3.2, 6.4 sec
5km crater: 0.0035, 0.0045, 0.09, 0.7, 0.9 sec
1km crater: 0.0027, 0.0070, 0.08, 0.7, 0.8 sec
The difference between the first two values is the time it took to find my longitude range using FindLevel versus BinarySearch. Which is why the 1-km crater took longer to do using FindLevel.
August 21, 2014 at 12:06 pm - Permalink
Pt_Lat_Temp[0,n1] = Pt_Lat_Temp[index_Temp[p]]
Pt_Lon_Temp[0,n1] = Pt_Lon_Temp[index_Temp[p]]
Pt_Ele_Temp[0,n1] = Pt_Ele_Temp[index_Temp[p]]
Variable firstToDelete= n1+1
Variable numToDelete= numpnts(Pt_Lat_Temp)-firstToDelete
DeletePoints firstToDelete, numToDelete, Pt_Lat_Temp,Pt_Lon_Temp,Pt_Ele_Temp
Wait; now that I look at this, how can you be certain you're not overwriting the input data?
That is, when assigning Pt_Lat_Temp[ somePoint ] = something
how do you know that a later assignment isn't READING the now-changed Pt_Lat_Temp[ somePoint ]?
August 21, 2014 at 12:11 pm - Permalink
August 21, 2014 at 12:21 pm - Permalink
3.61 vs 1.99 sec
0.18 vs 0.11 sec
0.17 vs 0.09 sec
August 21, 2014 at 12:33 pm - Permalink
I think I'll go through some of my other code now and replace FindLevel with BinarySearch and Sort with Extract, since I do that kind of thing elsewhere.
August 21, 2014 at 12:35 pm - Permalink
August 21, 2014 at 05:09 pm - Permalink
August 21, 2014 at 06:47 pm - Permalink
No.
August 21, 2014 at 08:21 pm - Permalink
Okay, then there's no point in making this one a ThreadSafe function. This particular one has nothing in it that could be threaded, though I was thinking a possible solution to my problem originally may've been to divide the data into (e.g.) 8 chunks, sort those, then sort the 8 chunks together -- a poor man's threaded sort until Igor implements it itself. Other parts of my code are threaded, though, like calculating volume or finding points within a polygon.
August 22, 2014 at 09:08 am - Permalink
