I feel that this should be a fairly simple code, but I seem to be having problems. I have a table with 2 columns. Each column has 64 points. I need to add point 1 from column 1 to point 1 from column 2, then point 2 in column 1 to point 2 in column 2, all the way to point 64. I would like to do this with out having to add each one individually, so I was wondering if anyone had an operation to do this. I also would like to display the results in the third column of the table just for an easy way to compare all the points.
Thank you for your help!
August 12, 2014 at 10:46 am - Permalink
August 12, 2014 at 11:31 am - Permalink
