Setvariable Procedure to Allow Use of Wavemetrics %w Formatting
// Code for using SI units and handling Wavemetrics' %w formatting code in setvarariable controls // The key point is use of a second variable to hold the absolute value of the previous value so we know order of magnitude // and can adjust for it when user types in a new value. The second copy of the variable is assumed to be named the same // as the main setvariable variable plus "SIS" and to be in the same datafolder. // The name of an additional function to run, if required, is stored in user data. //to make a sample test panel - make sure packages folder exists first: variable/G root:packages:MicrometerVal=0.15, root:packages:MicrometerValSIS =0.15 newpanel SetVariable micrometerSetVal,pos={5,5},size={145,17},proc= SIformattedSetVarProcAdjustInc, title="Micrometer" SetVariable micrometerSetVal,font="Arial",fSize=12,format="%.2W1Pm" SetVariable micrometerSetVal,limits={0,inf,0.01},value= root:packages:MicrometerVal SetVariable micrometerSetVal, userData = "myotherProc" //name of additional procedure // test additional function to run when value is changed (this is optional) function myotherProc(sva) : SetVariableControl STRUCT WMSetVariableAction &sva print "hello, my name is ", sva.ctrlname, "and my value is ", sva.dval + "." end ////////////////////////////////////////////////////////////////////////////////////////////////////////////////// // The Setvariable procedure Function SIformattedSetVarProc(sva) : SetVariableControl STRUCT WMSetVariableAction &sva variable eventCode =sva.eventCode string vName = sva.vName string ctrlName = sva.ctrlName controlinfo $ctrlName NVAR gVal = $S_DataFolder + vName FUNCREF SIformattedProtoSetVarfunc extraFunc = $sva.userdata //reference to additional function to run, if any switch (eventCode) case 1: // mouse up - Igor handles clicks properly, so just set back up variable NVAR valSIS = $S_DataFolder + vName + "SIS"//reference to backup value valSIS =abs (gVal) break case 2: // Enter key NVAR valSIS = $S_DataFolder + vName + "SIS"//reference to backup value if (valSIS < 10^-21) gVal /= 10^24 elseif (valSIS < 10^-18) gVal /= 10^21 elseif (valSIS < 10^-15) gVal /= 10^18 elseif (valSIS < 10^-12) gVal /= 10^15 elseif (ValSIS < 10^-9) gVal /= 10^12 elseif (ValSIS < 10^-6) gVal /= 10^9 elseif (valSIS < 10^-3) gVal /= 10^6 elseif (valSIS < 1) gVal /= 10^3 elseif (valSIS < 10^3) gVal *= 1 elseif (valSIS < 10^6) gVal *= 10^3 elseif (valSIS < 10^9) gVal *= 10^6 elseif (valSIS < 10^12) gVal *= 10^9 elseif (valSIS > 10^15) gVal *= 10^12 elseif (ValSIS > 10^18) gVal *= 10^15 elseif (ValSIS > 10^21) gVal *= 10^18 elseif(ValSIS > 10^24) gVal *= 10^21 else gVal *= 10^24 endif valSIS =abs (gVal) break case 3: // Live update - do nothing case -1: // killing - do nothing break endswitch //Run additional function, if it was given if (cmpstr (sva.userdata, "") != 0) sva.dVal = gVal //first update the struct with correct value extraFunc (sva) endif return 0 End ////////////////////////////////////////////////////////////////////////////////////////////////////////////////// //This version also dynamically adjusts the setvariable increment to 1 percent of the current order of magnitude of the variable. Function SIformattedSetVarProcAdjustInc(sva) : SetVariableControl STRUCT WMSetVariableAction &sva variable eventCode =sva.eventCode string vName = sva.vName string ctrlName = sva.ctrlName controlinfo $ctrlName NVAR gVal = $S_DataFolder + vName FUNCREF SIformattedProtoSetVarfunc extraFunc = $sva.userdata //reference to additional function to run, if any switch (eventCode) case 1: // mouse up - Igor handles clicks properly, so just set back up variable NVAR valSIS = $S_DataFolder + vName + "SIS"//reference to backup value valSIS =abs (gVal) break case 2: // Enter key NVAR valSIS = $S_DataFolder + vName + "SIS"//reference to backup value if (valSIS < 10^-21) gVal /= 10^24 elseif (valSIS < 10^-18) gVal /= 10^21 elseif (valSIS < 10^-15) gVal /= 10^18 elseif (valSIS < 10^-12) gVal /= 10^15 elseif (ValSIS < 10^-9) gVal /= 10^12 elseif (ValSIS < 10^-6) gVal /= 10^9 elseif (valSIS < 10^-3) gVal /= 10^6 elseif (valSIS < 1) gVal /= 10^3 elseif (valSIS < 10^3) gVal *= 1 elseif (valSIS < 10^6) gVal *= 10^3 elseif (valSIS < 10^9) gVal *= 10^6 elseif (valSIS < 10^12) gVal *= 10^9 elseif (valSIS > 10^15) gVal *= 10^12 elseif (ValSIS > 10^18) gVal *= 10^15 elseif (ValSIS > 10^21) gVal *= 10^18 elseif(ValSIS > 10^24) gVal *= 10^21 else gVal *= 10^24 endif valSIS =abs (gVal) break case 3: // Live update - do nothing case -1: // killing - do nothing break endswitch //Adjust the setvariable increment to 1 percent of current order of magnitude. //IMPORTANT - If your expected values will span 0,use non-adjusting version, as adjusting // the increment leads to a "Xeno-like paradox", where you can never click past 0 variable start, stop string limitStr start = strsearch (s_recreation, "limits={", 0) stop = strsearch (s_recreation, "}", start) limitStr = s_recreation [start + 8, stop-1] start = str2num (stringFromList (0, limitStr, ",")) stop = str2num (stringFromList (1, limitStr, ",")) //adjust increment based on magnitude of current value if (valSIS < 10.0001^-12) SetVariable $ctrlname limits={(start),(stop),10^-14} elseif (valSIS < 10.0001^-11) SetVariable $ctrlname limits={(start),(stop),10^-13} elseif (valSIS < 10.0001^-10) SetVariable $ctrlname limits={(start),(stop),10^-12} elseif (valSIS < 10.0001^-9) SetVariable $ctrlname limits={(start),(stop),10^-11} elseif (valSIS < 10.0001^-8) SetVariable $ctrlname limits={(start),(stop),10^-10} elseif (valSIS < 10.0001^-7) SetVariable $ctrlname limits={(start),(stop),10^-9} elseif (valSIS < 10.0001^-6) SetVariable $ctrlname limits={(start),(stop),10^-8} elseif (valSIS < 10.0001^-5) SetVariable $ctrlname limits={(start),(stop),10^-7} elseif (valSIS < 10.0001^-4) SetVariable $ctrlname limits={(start),(stop),10^-6} elseif (valSIS < 10.0001^-3) SetVariable $ctrlname limits={(start),(stop),10^-5} elseif (valSIS < 10.0001^-2) SetVariable $ctrlname limits={(start),(stop),10^-4} elseif (valSIS < 10.0001^-1) SetVariable $ctrlname limits={(start),(stop),10^-3} elseif (valSIS < 10^0) SetVariable $ctrlname limits={(start),(stop),10^-2} elseif (valSIS < 9.9999^1) SetVariable $ctrlname limits={(start),(stop),10^-1} elseif (valSIS < 9.9999^2) SetVariable $ctrlname limits={(start),(stop),10^0} elseif (valSIS < 9.9999^3) SetVariable $ctrlname limits={(start),(stop),10^1} elseif (valSIS < 9.9999^4) SetVariable $ctrlname limits={(start),(stop),10^2} elseif (valSIS < 9.9999^5) SetVariable $ctrlname limits={(start),(stop),10^3} elseif (valSIS < 9.9999^6) SetVariable $ctrlname limits={(start),(stop),10^4} elseif (valSIS < 9.9999^7) SetVariable $ctrlname limits={(start),(stop),10^5} elseif (valSIS < 9.9999^8) SetVariable $ctrlname limits={(start),(stop),10^6} elseif (valSIS < 9.9999^9) SetVariable $ctrlname limits={(start),(stop),10^7} elseif (valSIS < 9.9999^10) SetVariable $ctrlname limits={(start),(stop),10^8} elseif (valSIS < 9.9999^11) SetVariable $ctrlname limits={(start),(stop),10^9} elseif (valSIS < 9.9999^12) SetVariable $ctrlname limits={(start),(stop),10^10} endif //Run additional function, if it was given if (cmpstr (sva.userdata, "") != 0) sva.dVal = gVal //first update the struct with correct value extraFunc (sva) endif return 0 End ////////////////////////////////////////////////////////////////////////////////////////////////////////////////// //Prototype function for additional stuff do do when value changes function SIformattedProtoSetVarfunc (sva) : SetVariableControl STRUCT WMSetVariableAction &sva //Nothing happens here return 0 end
