    Self Modeling Curve Resolution (SMCR) Procedure
// Input: datamat is a 2D matrix whose columns are spectra obtained from two-component // solutions of different concentration. For example, the first spectrum can be that of a // pure solvent and the remaining spectra can have various (at least one) solute // concentrations. // There is no need to normalize the spectral measurements -- this is done // inside the function. // Output: component1 and component2, one of which is the minimum area solute correlated // spectrum, while the other is the minimum area spectrum pertaining to the pure solvent. // The pure solvent spectrum itself can be re-generated from the SMCR scores pertaining // to the pure solvent spectrum. For example, if the first spectrum (in column 0) is the pure // solvent then the following command will re-generate the pure solvent spectrum (solvent). // from the SMCR scores and PC loadings. // solvent=score1[0]*PCLoadings1+score2[0]*PCLoadings2 // Requires: IP 6.22 or newer. // Reference: Lawton and Sylvestre, Technometrics, volume 13, page 617, 1971 // Procedure written by: David Wilcox (wilcoxds at purdue dot edu) Function SMCR(datamat) wave datamat // the following command normalizes and transposes the input matrix. MatrixOP/O/FREE inMat=scaleCols(datamat,(powr(sumcols(datamat),-1)^t))^t Variable i,numRows //Calculate scores and loadings from SVD MatrixSVD inMat wave M_U, W_W, M_VT MatrixTranspose M_VT MatrixOP/O W_W=diagonal(W_W) MatrixOP /FREE/O PCLoadings1=col(M_VT,0) MatrixOP/FREE/O PCLoadings2=col(M_VT,1) MatrixOP/FREE/O aug_scores = M_U x W_W MatrixOP/FREE/O score1=col(aug_scores ,0) // PC1 scores for each input specxtrum MatrixOP/FREE/O score2=col(aug_scores ,1) // PC2 scores for each input specxtrum //Find minimum positive and maximum negative of loadings ratio (slopes) MatrixOP/O/FREE Lratio = PCLoadings1/PCLoadings2 numRows=DimSize(Lratio,0) variable m1,m2 i=0 m1=-10^100 m2=10^100 do if (Lratio[i] > 0) m1 = max(-Lratio[i],m1) elseif (Lratio[i] < 0) m2 = min(-Lratio[i],m2) endif i +=1 while (i<numRows) // Linear regression of scores ratio CurveFit /Q line, score2/x=score1 wave W_coef Variable m=W_coef[1] Variable b=W_coef[0] // Intersection of scores and loadings make/FREE/O/N=(2,2) x1x2num={{b,1},{0,1}} make/FREE/O/N=(2,2) x1y1denom={{-m,1},{-m1,1}} MatrixOP/FREE/O x1= Det(x1x2num)/Det(x1y1denom) // (x1,y1) is one end point of the PC score line make/FREE/O/N=(2,2) y1num={{-m,b},{-m1,0}} MatrixOP/FREE/O y1= Det(y1num)/Det(x1y1denom) make/FREE/O/N=(2,2) x2y2denom={{-m,1},{-m2,1}} MatrixOP/FREE/O x2= Det(x1x2num)/Det(x2y2denom) // (x2,y2) is one end point of the PC score line make/FREE/O/N=(2,2) y2num={{-m,b},{-m2,0}} MatrixOP/FREE /O y2 = Det(y2num)/Det(x2y2denom) // Make pure component spectra Variable x1v=x1[0],x2v=x2[0],y1v=y1[0],y2v=y2[0] MatrixOP/O component1 = x1v*PCLoadings1 + y1v*PCLoadings2 MatrixOP/O component2 = x2v*PCLoadings1 + y2v*PCLoadings2 KillWaves/Z M_U,W_W,M_VT,W_coef,W_sigma end
