Hierarchical clustering 2: Dendrogram
The code constructs a dendrogram from a dissimilarity matrix (see Hierarchical clustering for a code to generate the matrix).
Function BuildDendrogram iterates over cells in the matrix and finds the cell with the lowest distance. The cell is removed from the matrix and added to a branch of a dendrogram. The output is to wave: sortedDissimilaryMatrix which is the sorted / final output and DendPosX and DendPosY waves which construct the dendrogram. Old cell position is saved in ClusXTxT wave.
Example usage:
make/o/n=(100,10) testWave=gnoise(1)+mod(q,2)//---one cluster in even columnsand another in odd columns
MakeDisSimilarityMatrix(testWave)//---See Hierarchical clustering for the code. The resulting disSimilaryMatrix looks pixelated
BuildDendrogram(DisSimilarityMatrix)//---The sorted matrix is stored in sortedDissimilaryMatrix
Display/K=0 DendPosY vs DendPosX//---show the dendrogram
ModifyGraph userticks(bottom)={ClusX,ClusXTxT}//---show the original column information
//---helper function Function DendMeanLoc(DendTxT,matchSt) wave/t DendTxT string matchSt variable i,pos=0,numpnt=0 for(i=0;i<numpnts(DendTxT) ;i++) if(whichListItem(DendTxT[i],matchSt)>-1) pos+=i numpnt++ endif endfor return pos/numpnt end //---computes the dendrogram and similarity matrix Function BuildDendrogram(wave DisSimilarityMatrix) duplicate/o DisSimilarityMatrix,TempDisSimilarityMatrix //---matrix that is reduced in size for each step make/o/n=(dimsize(DisSimilarityMatrix,0))/t DendTxT=num2str(p),OrigDendTxT=num2str(p) //---original positions make/o/n=(1,3)/t DendClusTxT="" //---saves the number of the original (unsorted) values make/o/n=(1,3) DendClus=nan,DendClusX=nan //---the magnitude of the clusters (y axis on a dendrogram) make/o/n=(0)/t ClusXTxT make/o/n=0 DendPosX,DendPosY //---waves that draw the dendrogram variable run,clus //---iterate over the dissimilarity matrix to find the smallest distance and remove that cell from the matrix for(run=0;run<dimsize(DisSimilarityMatrix,0)-1;run++) //---over all cells in the dissimilarity matrix //---for each iteration find the cell with the smallest distance (value) imagestats/m=1 TempDisSimilarityMatrix variable minloc=min(V_minColLoc,V_minRowLoc) //---removed row variable maxloc=max(V_minColLoc,V_minRowLoc) //---removed col //---set the columns and the rows on the smallest value cell to the max value of the corresponding row and column TempDisSimilarityMatrix[minloc][]=max(TempDisSimilarityMatrix[minloc][q],TempDisSimilarityMatrix[maxloc][q]) //---find the max distance TempDisSimilarityMatrix[][minloc]=TempDisSimilarityMatrix[minloc][p] //---save position information and start building the dendrogram insertpoints 0,1, DendClusTxT,DendClus,DendClusX DendClusTxT[0][0]=DendTxT[minloc] //---info about child 1 (all the cells #) DendClusTxT[0][1]=DendTxT[maxloc] //---info about child 2 DendClusTxT[0][2]=DendClusTxT[0][0]+";"+DendClusTxT[0][1] //---parent - a list of all the cells in child1 and child 2 //---modify the positions for the dendrogram for(clus=0;clus<numpnts(OrigDendTxT);clus++) if(stringmatch(OrigDendTxT[clus],DendClusTxT[0][0])) //---child 1 is a terminal branch insertpoints numpnts(ClusXTxT),1,ClusXTxT ClusXTxT[ numpnts(ClusXTxT)-1 ]=OrigDendTxT[clus] //---save the original position DendClus[0][0]=0 endif if(stringmatch(OrigDendTxT[clus],DendClusTxT[0][1])) //---child 2 is a terminal branch insertpoints numpnts(ClusXTxT),1,ClusXTxT ClusXTxT[ numpnts(ClusXTxT)-1 ]=OrigDendTxT[clus] //---save the original position DendClus[0][1]=0 endif endfor for(clus=0;clus<dimsize(DendClusTxT,0);clus++) if(stringmatch(DendClusTxT[0][0],DendClusTxT[clus][2])) DendClus[0][0]=DendClus[clus][2] endif if(stringmatch(DendClusTxT[0][1],DendClusTxT[clus][2])) DendClus[0][1]=DendClus[clus][2] endif endfor //---ready to remove the cell DendClus[0][2]=v_min DendTxT[minloc]=DendClusTxT[0][2] DendClusX[0][0]=DendMeanLoc(ClusXTxT,DendClusTxT[0][0]) //---X position info (for display only) deletepoints /m=0 maxloc,1, TempDisSimilarityMatrix,DendTxT deletepoints /m=1 maxloc,1, TempDisSimilarityMatrix endfor killwaves/z TempDisSimilarityMatrix //---normalize the dendrogram variable PeakVal=wavemax(DendClus) DendClus=DendClus/PeakVal*100 variable i //---sort the dendrogram make/o/n=(itemsinlist(DendClusTxT[0][2]))/t ClusXTxT string/g ClusSortedLocation="" for(i=0;i<itemsinlist(DendClusTxT[0][2]);i++) ClusXTxT[i]=stringfromlist(i,DendClusTxT[0][2]) //---new position ClusSortedLocation+=ClusXTxT[i]+";" endfor //---drawing utilities for(clus=0;clus<dimsize(DendClus,0);clus++) insertpoints 0,5,DendPosX,DendPosY //---position of the branches DendPosX[0,1]=DendMeanLoc(ClusXTxT,DendClusTxT[clus][0]) DendPosX[2,3]=DendMeanLoc(ClusXTxT,DendClusTxT[clus][1]) DendPosX[4]=nan DendPosY[0]=DendClus[clus][0] DendPosY[1,2]=DendClus[clus][2] DendPosY[3]=DendClus[clus][1] DendPosY[4]=nan endfor //---sorting make/o/n=(numpnts(ClusXTxT)) ClusX=p //---just the position (p) duplicate/o DisSimilarityMatrix,SortedDisSimilarityMatrix SortedDisSimilarityMatrix[][]=DisSimilarityMatrix[str2num(ClusXTxT[p])][str2num(ClusXTxT[q])] end
