getXRDML() - function to load xrdml data from Panalytical diffractometers using the XOP XMLutils
It creates a folder for each xrdml-file read. The foldername will be the xrdml-filename in lower case letters without the fileextension. The intensities are loaded into waves called 'intensities##' stored in the folder /XMLutil/XRD/'filename'.
It can also handle mutiple (repeated) scans in one xrdml-file by assigning a number '##' to each intensities wave. It also reads the scan comments and additional information about each scan in the file like scannumber, start-,endtime, start-,endposition, measurement program and so on and stores them in a note to each intensities wave.
I am grateful to andyfaff for helping me putting his XMLutils to use with the xrdml files and for reviewing this snippet.
#pragma rtGlobals=1 // Use modern global access method.
Function getXRDML()
variable fileID
variable ii, llength, numscans, iii, numcommlines, start, finish, numrows
string folder="", noteStr="", noteAddStr="", noteFinStr=""
open/r/d/t="????"/M="Please select the XRDML file" fileID
if(strlen(S_filename)>0)
fileID = XMLopenfile(S_fileName)
if(fileID<1)
print "Error, can't load file"
//Make DataFolder according to XRDML-Filename
llength = ItemsInList(S_fileName, ":")
folder = StringFromList(llength-1, S_fileName, ":")
folder = RemoveEnding(lowerstr(folder), ".xml")
folder = RemoveEnding(lowerstr(folder), ".xrdml")
//printf "\rfolder=%s", folder
NewDataFolder/S/O root:XMLutils
NewDataFolder/S/O root:XMLutils:XRD
NewDataFolder/S/O $folder
//find out how many scans there were.
XMLlistXpath(fileID, "//xrdml:scan", "xrdml=http://www.xrdml.com/XRDMeasurement/1.3")
Wave/t M_listXPath
numscans = dimsize(M_listXPath,0)
//get measurement info and add as note to the wave
XMLwaveFmXPath(fileID, "/xrdml:xrdMeasurements/xrdml:comment/xrdml:entry", "xrdml=http://www.xrdml.com/XRDMeasurement/1.3", "\n")
Wave/T M_xmlContent, W_xmlContentNodes
numcommlines=dimsize(M_xmlContent,1)
for(iii=0; iii<numcommlines; iii+=1)
noteStr=noteStr+M_xmlContent[0][iii]+"\r"
//get measurement program comment
XMLwaveFmXPath(fileID, "/xrdml:xrdMeasurements/xrdml:xrdMeasurement/xrdml:comment/xrdml:entry", "xrdml=http://www.xrdml.com/XRDMeasurement/1.3", "\n")
noteStr=noteStr+"Measurement program comment:\r"+M_xmlContent[0][0]+"\r"
//get sample id
XMLwaveFmXPath(fileID, "//xrdml:sample/xrdml:id", "xrdml=http://www.xrdml.com/XRDMeasurement/1.3", "\n")
noteStr=noteStr+"Sample Name: "+M_xmlContent[0][0]+"\r"
//get generator/tube info
XMLwaveFmXPath(fileID, "//xrdml:incidentBeamPath/xrdml:xRayTube/xrdml:anodeMaterial", "xrdml=http://www.xrdml.com/XRDMeasurement/1.3", "\n")
noteStr=noteStr+"Tube: " + XMLstrFmXPath(fileID, "//xrdml:incidentBeamPath/xrdml:xRayTube/@name", "xrdml=http://www.xrdml.com/XRDMeasurement/1.3", "") + " @ "
XMLwaveFmXPath(fileID, "//xrdml:incidentBeamPath/xrdml:xRayTube/xrdml:tension", "xrdml=http://www.xrdml.com/XRDMeasurement/1.3", "\n")
noteStr=noteStr+M_xmlContent[0][0]+"kV/"
XMLwaveFmXPath(fileID, "//xrdml:incidentBeamPath/xrdml:xRayTube/xrdml:current", "xrdml=http://www.xrdml.com/XRDMeasurement/1.3", "\n")
noteStr=noteStr+M_xmlContent[0][0]+"mA\r"
//get wavelength info
XMLwaveFmXPath(fileID, "//xrdml:usedWavelength", "xrdml=http://www.xrdml.com/XRDMeasurement/1.3", "\n")
noteStr=noteStr+"Wavelengths:\rkAlpha1: "+M_xmlContent[0][0]+"\rkAlpha2: "+M_xmlContent[0][1]+"\rkBeta: "+M_xmlContent[0][2]+"\r"
//load all the xrd intensities in.
for(ii=1 ; ii<numscans+1 ; ii+=1)
//load the intensities and put the scaling on the wave
XMLwaveFmXpath(fileID, "//xrdml:scan["+num2str(ii)+"]/xrdml:dataPoints/xrdml:intensities", "xrdml=http://www.xrdml.com/XRDMeasurement/1.3", "")
numrows = dimsize(M_xmlContent,0)
make/o/d/n=(numrows) $"intensities"+num2istr(ii)
Wave intensity = $"intensities"+num2istr(ii)
intensity = str2num(M_xmlcontent)
//get scan info and add to the wave note
//get start/end time of scan
noteAddStr=noteAddStr + "--- Scan #"+num2str(ii)+"---\r"
noteAddStr=noteAddStr+"Start time: " + XMLstrFmXPath(fileID, "//xrdml:scan["+num2str(ii)+"]/xrdml:header/xrdml:startTimeStamp", "xrdml=http://www.xrdml.com/XRDMeasurement/1.3", "") +"\r"
noteAddStr=noteAddStr+"End time: " + XMLstrFmXPath(fileID, "//xrdml:scan["+num2str(ii)+"]/xrdml:header/xrdml:endTimeStamp", "xrdml=http://www.xrdml.com/XRDMeasurement/1.3", "") +"\r"
//here comes the scaling
XMLwaveFmXpath(fileID, "//xrdml:scan["+num2str(ii)+"]//xrdml:positions[@axis='2Theta']/xrdml:startPosition", "xrdml=http://www.xrdml.com/XRDMeasurement/1.3", "")
start = str2num(M_xmlcontent[0])
noteAddStr = noteAddStr + "Start position: " + M_xmlContent[0] +"\r"
XMLwaveFmXpath(fileID, "//xrdml:scan["+num2str(ii)+"]//xrdml:positions[@axis='2Theta']/xrdml:endPosition", "xrdml=http://www.xrdml.com/XRDMeasurement/1.3", "")
finish = str2num(M_xmlcontent[0])
noteAddStr = noteAddStr + "End position: " + M_xmlContent[0] +"\r"
noteFinStr=noteStr+noteAddStr
Note/NOCR intensity, noteFinStr
noteAddStr=""
noteFinStr=""
SetScale/I x, start, finish, intensity
killwaves/z M_Xmlcontent, W_xmlcontentnodes, M_listXPath
if(fileID)
xmlclosefile(fileID, 0)
SetDataFolder root:XMLutils:XRD
