Folder Selector
#pragma rtGlobals=1 // Use modern global access method. // Window Recreation Window Folder_Selector() : Panel Makelist() PauseUpdate; Silent 1 // building window... NewPanel /W=(434,276,689,553) as "Folder Selector" SetDrawLayer UserBack DrawText 19,34,"Double click on the folder to set as active" ListBox list0,pos={19,52},size={75,132},proc=ListBox_G,frame=0 ListBox list0,listWave=root:lista,mode= 2,selRow= 0 EndMacro // List Box Control Function ListBox_G(ctrlName,row,col,event) : ListBoxControl String ctrlName Variable row Variable col Variable event //1=mouse down, 2=up, 3=dbl click, 4=cell select with mouse or keys //5=cell select with shift key, 6=begin edit, 7=end WAVE lista=root:lista if (event == 3) String/G nombre //name of the current Folder string cmd sprintf cmd," nombre = root:lista[%g]", row execute cmd if (cmpstr (nombre,"root:") == 0) setdatafolder root: else nombre = "root:"+ nombre setdatafolder $nombre endif print nombre setdatafolder $nombre endif return 0 End // Folders List Function Function Makelist() string objName variable n,i i=0 n = CountObjects(":",4) Make/O /T /N=(n+1) lista lista[0] = "root:" do objName = GetIndexedObjName(":", 4, i) if (strlen(objName) == 0) break endif lista[i+1]=objName i=i+1 print i while(1) end
works better whit liberal names.
May 26, 2008 at 10:31 am - Permalink
Why do you need the global variable and execute? Can't you do it this way:
May 27, 2008 at 04:04 pm - Permalink
