df-like Utility to Estimate Data Folder Size
This utility routine computes a lower bound on the size of data folders and optionally their children using techniques discussed / implemented elsewhere on IgorExchange (c.f. FindBigWaves, SizeOfType). It is extended to handle text as well as numeric waves as the helper function wSize, and accounts for the wave note.
An optional summary of the traversed data folder tree with it's estimated size in MB can be printed to the history by passing the optional depth parameter.
If one does not care about error in estimating size of complex variables, dfSize can easily be made ThreadSafe, as indicated.
// dfSize: Given a data folder reference, estimates the size, in bytes, of its contents.
// This will be an underestimate, as it does not properly treat special waves such as DFREFs, etc.
// Wave sizes are estimated with wSize, and are subject to its limitations.
// If the optional depth parameter is specified with a positive integer, prints directory status updates
// up to depth from dfr with size in MB.
Function dfSize(dfr, [depth, curDepth])
    DFREF dfr
    Variable depth // print depth size updates
    Variable curDepth // current depth
    if(ParamIsDefault(depth))
        depth = NaN
    if(ParamIsDefault(curDepth))
        curDepth = 0
    DFREF dfSave = GetDataFolderDFR()
    SetDataFolder dfr
    Variable i
    Variable byteSum = 0
    String curName = ""
    Variable numDFs = CountObjectsDFR(dfr, 4)
    for(i = 0; i < numDFs; i += 1)
        curName = GetIndexedObjNameDFR(dfr, 4, i)
        DFREF curDF = $curName
        byteSum += dfSize(curDF, depth = depth, curDepth = curDepth + 1)
    // Children are handled; do sum
    Variable nvarSiz = 0
    Variable wavSiz = 0
    Variable svarSiz = 0
    for(i = 0; i < CountObjectsDFR(dfr, 3); i += 1)
        curName = GetIndexedObjNameDFR(dfr, 3, i)
        SVAR curSVAR = $curName
        svarSiz += strlen(curSVAR)
    // NVARS are always floating point, but might be complex
    nvarSiz += 4 * ItemsInList(VariableList("*", ";", 4)) + 8 * ItemsInList(VariableList("*", ";", 5))
// This would need to be enabled for a ThreadSafe implementation, should a means to test NVARs for complex-ness be found
//  for(i = 0; i < CountObjectsDFR(dfr, 2); i += 1)
//      curName = GetIndexedObjNameDFR(dfr, 2, i)
//      SVAR curNVAR = $curName
//      nvarSiz += 4
//  endfor
    for(i = 0; i < CountObjectsDFR(dfr, 1); i += 1)
        curName = GetIndexedObjNameDFR(dfr, 1, i)
        WAVE curWAV = $curName
        wavSiz += wSize(curWav)
    byteSum += wavSiz + nvarSiz + svarSiz
    if(numType(depth) == 0)
        if(curDepth <= depth)
            Print GetDataFolder(1), byteSum / 2^20
    SetDataFolder dfSave
    return byteSum
// wSize: Returns a lower bound, in bytes, of an arbitrary wave's size based on its type and length. (Proprietary header
// information, dimension labels, etc. are not incorportated.)
ThreadSafe Function wSize(wav)
    WAVE wav
    String retName // Name of target wave
    WAVE nullWav // Null wave reference
    Variable typeCode
    Variable i, j, k, L
    Variable siz = 0
    Variable sizeOfType = 1
    Variable noteSize = 0
    switch(WaveType(wav, 1))
    case 0: // Null wave
    case 3: // DF wave
    case 4: // WAVE wave
        // Do nothing
    case 2:
        // Text wave
        // Cast wav as a text format
        WAVE/T txtWavCast = $GetWavesDataFolder(wav, 2)
        switch(WaveDims(txtWavCast))
        case 0:
        case 1:
            for(i = 0; i < DimSize(txtWavCast, 0); i += 1)
                siz += strlen(txtWavCast[i])
            break
        case 2:
                for(j = 0; j < DimSize(txtWavCast, 1); j += 1)
                    siz += strlen(txtWavCast[i][j])
            break
        case 3:
                    for(k = 0; k < DimSize(txtWavCast, 2); k += 1)
                        siz += strlen(txtWavCast[i][j][k])
            break
        case 4:
                        for(L = 0; L < DimSize(txtWavCast, 3); L += 1)
                            siz += strlen(txtWavCast[i][j][k][L])
            break
        endswitch
        // Don't forget the wave's note!
        noteSize = strlen(note(wav))
        return siz + noteSize
    endswitch
    // Numeric wave
    typeCode = WaveType(wav)
    // Need to return an appropriate WAVE reference type
    Variable waveIsComplex = typeCode & 0x01
    Variable waveIs32BitFloat = typeCode & 0x02
    Variable waveIs64BitFloat = typeCode & 0x04
    Variable waveIs8BitInteger = typeCode & 0x08
    Variable waveIs16BitInteger = typeCode & 0x10
    Variable waveIs32BitInteger = typeCode & 0x20
    Variable waveIsUnsigned = typeCode & 0x40
    // Determine wave type size multiplier
    // inspired by AG, WaveMetrics; igorexchange.com / node / 1845
    if(waveIsComplex)
        sizeOfType *= 2
    if(waveIs32BitFloat)
        sizeOfType *= 4
    elseif(waveIs64BitFloat)
        sizeOfType *= 8
    elseif(waveIs16BitInteger)
        sizeOfType *= 2
    elseif(waveIs32BitInteger)
        sizeofType *= 4
    return numpnts(wav) * sizeOfType + noteSize
