Convert Triplet data from grid into Matrix
gridTripletToMatrix(triplet_wave)
, takes such triplet data and converts it to a matrix (without any interpolation). The function does not require any particular ordering of the triplet (xyz) sequences, although this might often occur in a matrix-like order. If the original data is in the form of three x, y, and z waves it should be converted to a triplet wave. An alternative is to modify the code below to accept three 1D waves directly (which it does internally from the triplet wave). The first function foo()
tests the conversion function for a triplet wave which has a randomly altered sequence order. The conversion function should be treated more as a code example than a bullet-proof WaveMetrics-class utility.#pragma rtGlobals=1 // Use modern global access method. #include <MatrixToXYZ> // Generate simulated test data, and put it in a triplet wave with random row order. // Test the matrix rearrangement function, comparing it to the original matrix that // was used to create the simulated data. These can also be compared in Tables // or Gizmo plots. function foo() variable Nx0 = 14, Ny0 = 12 make/O/N=(Nx0,Ny0) wave0 // form a gridded original source setscale/P x, -0.1*Nx0/2, 0.1,"" wave0 setscale/P y, -0.1*Ny0/2, 0.1,"" wave0 wave0 = exp( - 4*(x^2+y^2)) + gnoise(0.025) // original 'data' quad surface wave Execute "MatrixToXYZTriplet(\"wave0\",\"triplet\",2)" wave triplet // in gridded sequence at this point variable Ntriplet = DimSize(triplet,0) Make/O/N=(Ntriplet) wx, wy, wz // convert to xyz 1D waves MatrixOP/O wx = col(triplet,0) MatrixOP/O wy = col(triplet,1) MatrixOP/O wz = col(triplet,2) shuffle(Ntriplet) // random permutation key wave wPerm Sort wPerm, wx, wy, wz // randomize order of 1D components Make/O/N=((Ntriplet), 3 ) wRanTrip // re-assemble triplet wave, in random order wRanTrip[][0] = wx[p] wRanTrip[][1] = wy[p] wRanTrip[][2] = wz[p] // simulated triplet data gridTripletToMatrix(wRanTrip) // TEST THE SORTING AND GRIDDING FUNCTION wave wz2D // the resulting 2D matrix wave MatrixOP/O wdiff = wave0 - wz2D MatrixOP/O var = (1/(Nx0*Ny0)) * sum(wdiff*wdiff) printf "wdiff Variance = %g\r", var[0] // error between original and rearranged test end //----------------------------------------------------------------------------------------------------------------- // The input must be an (N,3) triplet wave, whose x and y components are on a // rectangular grid, so each (x,y) pair is unique. The dim-0 ordering of each triplet can // be arbitrary, since the function will sort the row order and find the grid dimensions. // The resulting 2D wave containing the 'z' values on a scaled x-y grid is 'wz2D'. // Internal waves are created as /FREE; change this if you wish to inspect them later. // There is no error checking on the input wave to ensure the triplet criteria ! ! ! function gridTripletToMatrix(triplet_wave) // sort the triplet order, and grid the data wave triplet_wave // triplet input wave in arbitray order variable Npts = DimSize(triplet_wave,0) Make/O/N=(Npts)/FREE wxR, wyR, wzR // convert to x,y,z MatrixOP/O wxR = col(triplet_wave,0) MatrixOP/O wyR = col(triplet_wave,1) MatrixOP/O wzR = col(triplet_wave,2) sort wyR, wxR, wyR, wzR // sort all waves by y values variable Nx, Ny, i variable tol = 1e-6 for(i=0;i<Npts;i+=1) // find the dimension boundary if ( wyR[i+1]> (wyR[i] + tol* abs(wyR[i])) ) // allow for numeric error Nx = i+1 // Nx is the x dimension size break endif endfor Ny = Npts / Nx // Ny is the y dimension size Make/O/N=0/FREE wxB, wyB, wzB // initial 'big' target wave for concatenating chunks Make/O/N=(Nx)/FREE wxS, wyS, wzS // Nx chunks ('S' for 'small') for(i=0; i<Ny; i+=1) wxS = wxR[p+i*Nx]; wyS = wyR[p+i*Nx]; wzS = wzR[p+i*Nx] Sort wxS, wxS, wzS // sort x and z in each chunk wave by x values Concatenate/NP {wxS}, wxB; Concatenate/NP {wyS}, wyB; Concatenate/NP {wzS}, wzB endfor Make/O/N=((Nx*Ny), 3 )/FREE wSortedTriplet // triplet wave, grid sorted wSortedTriplet[][0] = wxB[p] wSortedTriplet[][1] = wyB[p] wSortedTriplet[][2] = wzB[p] MatrixOP/O wz2D = col(wSortedTriplet,2) // sorted z-values in a 1D wave Redimension/N=(Nx,Ny) wz2D // Make/O/N=(Nx, Ny) wz2D // alternate method:set up the rectangular gridded wave // wz2D = wz1D[p+Nx*q] // for 'z' values, and"unfold" 'z' values from 1D wave into 2D wave variable dx = wSortedTriplet[1][0] - wSortedTriplet[0][0] variable dy = wSortedTriplet[Nx][1] - wSortedTriplet[0][1] variable FirstX = wSortedTriplet[0][0] , LastX = wSortedTriplet[Nx-1][0] + dx variable FirstY = wSortedTriplet[0][1] , LastY = wSortedTriplet[Npts-1][1] + dy SetScale x, FirstX, LastX, "" wz2D // using SetScale/I or/P gives scale precision errors SetScale y, FirstY, LastY,"" wz2D end //----------------------------------------------------------------------------------------------------------------- function shuffle(Npts) // perform a random permutation of indices 0...Npts-1 variable Npts make/O/N=(Npts) wPerm = p // will be used as sort key; initialize it variable i, j, temp for(i=Npts-1; i>0; i-=1) temp = wPerm[i] j = round( i/2+enoise(i/2) ) // pick random index from remaining choices wPerm[i] = wPerm[j] // swap entries wPerm[j] = temp endfor // wPerm is the final random sort key wave end
November 23, 2012 at 10:14 am - Permalink
