Clone Window
Clone a window, i.e. make an exact copy of a graph, table, etc. with the same axes, traces, etc. The waves in the original and the clone are shared between the two (no data is copied).
Function CloneWindow([win,replace,with,freeze])
    String win // Name of the window to clone.
    String replace,with // Replace some string in the windows recreation macro with another string.
    Variable freeze // Make a frozen clone (basically just a picture).
    if(ParamIsDefault(replace) || ParamIsDefault(with))
        replace=""; with=""
    if(ParamIsDefault(win))
        win=WinName(0,1)
    String win_rec=WinRecreation(win,0)
    Variable i
    for(i=0;i<ItemsInList(replace);i+=1)
        String one_replace=StringFromList(i,replace)
        String one_with=StringFromList(i,with)
        win_rec=ReplaceString(one_replace,win_rec,one_with)
    if(freeze)
        Struct rect coords
        GetWinCoords(win,coords)
        SavePICT /WIN=$win as "Clipboard"
        String newName=UniqueName(win,6,0)
        LoadPICT /O/Q "Clipboard",$newName
        Display /N=$newName /W=(coords.left,coords.top,coords.right,coords.bottom)
        DrawPICT /W=$newName 0,0,1,1,$newName
        Execute /Q win_rec
CloneWindow, but replace all the traces with copies and puts those copies in one data folder. Data is not shared between the original and the clone.
Function CloneWindow2([win,name,times])
    String win
    String name // The new name for the window and data folder.
    Variable times // The number of clones to make.  Clones beyond the first will have _2, _3, etc. appended to their names.
        win=WinName(0,1)
    if(ParamIsDefault(name))
        name=UniqueName2(win,"6;11")
        name=CleanupName(name,0)
    times=ParamIsDefault(times) ? 1 : times
    String curr_folder=GetDataFolder(1)
    NewDataFolder /O/S root:$name
    String traces=TraceNameList(win,";",3)
    Variable i,j
    for(i=0;i<ItemsInList(traces);i+=1)
        String trace=StringFromList(i,traces)
        Wave TraceWave=TraceNameToWaveRef(win,trace)
        Wave /Z TraceXWave=XWaveRefFromTrace(win,trace)
        Duplicate /o TraceWave $NameOfWave(TraceWave)
        if(waveexists(TraceXWave))
            Duplicate /o TraceXWave $NameOfWave(TraceXWave)
    // Copy error bars if they exist.  Won't work with subrange display syntax.
    for(i=0;i<ItemsInList(win_rec,"\r");i+=1)
        String line=StringFromList(i,win_rec,"\r")
        if(StringMatch(line,"*ErrorBars*"))
            String errorbar_names
            sscanf line,"%*[^=]=(%[^)])",errorbar_names
            for(j=0;j<2;j+=1)
                String errorbar_path=StringFromList(j,errorbar_names,",")
                sscanf errorbar_path,"%[^[])",errorbar_path
                String errorbar_name=StringFromList(ItemsInList(errorbar_path,":")-1,errorbar_path,":")
                Duplicate /o $("root"+errorbar_path) $errorbar_name
    for(i=1;i<=times;i+=1)
        Execute /Q win_rec
        if(i==1)
            DoWindow /C $name
            DoWindow /C $(name+"_"+num2str(i))
        ReplaceWave allInCDF
    SetDataFolder $curr_folder
Thank you for this excellent snippet. One note/question on CloneWindow2: I had to include a colon after "root" when duplicating my error bar waves or they weren't created in the new data folder.
Duplicate /o $("root:"...
Any thoughts on this? Thanks!
CloneWindow2 code is now failing for me. This line:
does not work on a graph I have where the line is: "ErrorBars/T=0/L=0 r_TCP_710C_2min_0006_C Y,wave=(:WAXS:TCP_710C_2min_0006_C:s_TCP_710C_2min_0006_C,:WAXS:TCP_710C_2min_0006_C:s_TCP_710C_2min_0006_C)". errorbar_names is empty string after that line.
This is Igor 8.04. I think the problem are my parameters to Errorbars : /T=0/L=0. Can the syntax be changed to look for the content after the last "=" sign and skip the previous ones, if any are present?
I think I fixed it, not sure if this will work always, but here is small code change which seems to work for me now:
            SplitString/E=",.*" line
            sscanf S_value,"%*[^=]=(%[^)])",errorbar_names
            for(j=0;j<2;j+=1)
Note, I added SplitString which splits the "line" at first "," to remove ErrorBars with flags (which may contain additional "=").
Also, I needed to remove the ":" from "root" in the Duplicate command.
