A char2num function that works for ASCII codes 0-->255.
i.e. one gets around the problem:
print char2num(num2char(56)) 56 print char2num(num2char(249)) -7 print num2char(249) ÿ
Function extendedASCIIchar2num(chars) string chars make/o/t/n=(strlen(chars),2) W_chartranslation variable ii,decChar for(ii=0 ; ii < strlen(chars) ; ii+=1) W_chartranslation[ii][0] = chars[ii] decChar = char2num(chars[ii]) if( 0 <= decChar && decChar <= 127) W_chartranslation[ii][1] = num2istr(decChar) else W_chartranslation[ii][1]= num2istr(255 + decChar + 1) endif endfor End
