Change All Dots to Comma in File
// ChangeAllDotsToCommaInFile(pathName, fileName) // Changes all dot characters to commas in the specified file. // You might want to do this to output a data file that represents numbers using the conventional European decimal separator. // NOTE: This may not work for Asian text that contains double-byte characters. Function ChangeAllDotsToCommaInFile(pathName, fileName) String pathName // Name of an Igor symbolic path or "" String fileName // Name of file or full path to file Variable refNum // Open source file and read the raw text from it into a string variable Open/Z=1/P=$pathName refNum as fileName if (V_flag != 0) return -1 // pathName and fileName do not fully specify the file to be opened endif FStatus refNum // Sets V_logEOF Variable numBytesInFile = V_logEOF String text = PadString("", numBytesInFile, 0x20) FBinRead refNum, text // Read entire file into variable. text = ReplaceString(".", text, ",") FSetPos refNum, 0 // Write string back to file FBinWrite refNum, text Close refNum return 0 End
