Set Igor Sleep Meter
jjweimer
// Igor Sleep Meter // // Creates a slider that can be used to adjust the relative attention level given to Igor // This procedure only has use under MacOS, not Windows // Higher values of sleep mean Igor spends less time looking for something to do // A value of ZERO gives full time to Igor as a foreground application #pragma rtGlobals=1 Function SetIgorSleep() if (WinType("IgorSleep")==0) NewPanel/W=(150,50,217,171)/K=1/N=IgorPower as "IgorSleep" Slider Power,pos={7,21},size={47,80},proc=SleepNumber,limits={0,20,1},value= 1 endif SetProcessSleep 1 End Function SleepNumber(sa) : SliderControl STRUCT WMSliderAction &sa switch( sa.eventCode ) case -1: // kill SetProcessSleep 1 break default: if( sa.eventCode & 1 ) // value set SetProcessSleep sa.curval endif break endswitch return 0 End
