whois lookup search in IGOR.
andyfaff
Requires SOCKIT XOP.
#pragma rtGlobals=1 // Use modern global access method. Function whois(IP_Host, server) string IP_Host //contains IP address (137.157.202.40) or host name (google.com) variable server //whois server variable socknum = 0 make/t/o whoisbuffer Wave/t whoisbuffer string servername switch(server) case 0: //RIPE servername = "whois.ripe.net" break case 1: //Asia-Pacific == APNIC servername = "whois.apnic.net" break case 2: //ARIN servername = "whois.arin.net" break case 3: //AfriNIC servername = "whois.afrinic.net" break case 4: //LACNIC servername = "whois.lacnic.net" break case 5: //internic servername = "whois.internic.net" break case 6: //networksolutions servername = "whois.networksolutions.com" break endswitch sockitopenconnection/q socknum, servername, 43, whoisbuffer if(V_flag == 0) sockitsendnrecv/TIME=10 sockNum, IP_HOST+"\r\n" if(V_Flag==0) S_tcp = replacestring("\n", S_tcp, "\r") print S_tcp else print "Error, whois lookup failed for some reason" killwaves/z whoisbuffer return 1 endif else print "Error, connection to whois server not made" killwaves/z whoisbuffer return 1 endif killwaves/z whoisbuffer End
