Get a streetmap of where you live using OpenStreetMap.org (via Google Geocaching)
andyfaff
To use type:
getPlotOfAddress("New Illawarra Rd Sydney Australia", 10000)
Where the first string is a search string you would use on googlemaps. The second number is the length of the image square you want.
It works by using Geoff Duttons code to work out the lat/long of the address you enter using Google geocaching. Then this lat-long is sent to Openstreetmap.org to get a maptile. It works fairly well but needs some experimentation with the zoom level and the scale of the map requested.
Please use responsibly, don't overdo it and get blacklisted by Google/OpenStreetmap by trying to programatically download maps of the world.
#pragma rtGlobals=1 // Use modern global access method. CONSTANT DEG2RAD = 0.01745329; CONSTANT RAD2DEG = 57.29577951; Structure GPSpos variable UTMNorthing variable UTMEasting string UTMzone variable Lat variable Long Endstructure Function getPlotOfAddress(address, zoomlevel) string address variable zoomlevel variable minLong, maxLong, minLat,maxLat struct GPSpos gps struct GPSpos mapArea //get the lat/long of the address Geocodewithgoogle(address, gps) //convert to UTM so that we can get a zoom box LLtoUTM(22, gps.lat, gps.Long, gps) minLat = gps.UTMNorthing-zoomLevel/2 maxLat = gps.UTMNorthing+zoomLevel/2 minLong = gps.UTMEasting-zoomLevel/2 maxLong = gps.UTMEasting+zoomLevel/2 //convert the min long in UTM to LL UTMtoLL(22, minLong, minLat, gps.UTMzone, maparea) minlong = mapArea.long minlat = mapArea.lat //convert the max long in UTM to LL UTMtoLL(22, maxLong, maxLat, gps.UTMzone, maparea) maxlong = mapArea.long maxlat = mapArea.lat string url="", fiLoc="" fiLoc = SpecialDirpath("Temporary",0,0,0 )+"abcd.png" sprintf url, "http://www.openstreetmap.org/export/finish?maxlat=%g&minlon=%g&maxlon=%g&minlat=%g&format=mapnik&mapnik_format=png&mapnik_scale=25000&osmarender_format=png&osmarender_zoom=4&commit=Export",maxLat, minLong, maxLong,minLat easyHttp/File=filoc url ImageLoad/T=png/O/G fiLoc End Function LLtoUTM( ReferenceEllipsoid, Lat, Long, gps) //converts lat/long to UTM coords. Equations from USGS Bulletin 1532 //East Longitudes are positive, West longitudes are negative. //North latitudes are positive, South latitudes are negative //Lat and Long are in decimal degrees //Written by Chuck Gantz- chuck.gantz@globalstar.com variable ReferenceEllipsoid, Lat, Long struct GPSpos &gps variable UTMEasting, UTMNorthing string UTMZone make/o/d/n=(23) EquatorialRadius, SquareOfEccentricity make/o/n=23/T EllipsoidName EquatorialRadius={6377563, 6378160, 6377397, 6377484, 6378206, 6378249, 6377276, 6378166, 6378150, 6378160, 6378137, 6378200, 6378270, 6378388, 6378245, 6377340, 6377304, 6378155, 6378160, 6378165, 6378145, 6378135, 6378137} SquareOfEccentricity={.00667054,.006694542,.006674372,.006674372,.006768658,.006803511,.006637847,.006693422,.006693422,.006694605,.00669438,.006693422,.00672267,.00672267,.006693422,.00667054,.006637847,.006693422,.006694542,.006693422,.006694542,.006694318,.00669438} EllipsoidName={"Airy","Australian National","Bessel 1841","Bessel 1841 (Nambia) ","Clarke 1866","Clarke 1880","Everest","Fischer 1960 (Mercury) ","Fischer 1968","GRS 1967", "GRS 1980", "Helmert 1906","Hough", "international", "Krassovsky", "Modified Airy", "Modified Everest", "Modified Fischer 1960", "South American 1969","WGS 60","WGS 66","WGS-72", "WGS-84"} variable a = EquatorialRadius[ReferenceEllipsoid] variable eccSquared = SquareOfEccentricity[ReferenceEllipsoid]; variable k0 = 0.9996; variable LongOrigin; variable eccPrimeSquared; variable N, T, C, AA, M; //Make sure the longitude is between -180.00 .. 179.9 variable LongTemp = (Long+180)-floor((Long+180)/360)*360-180; // -180.00 .. 179.9; variable LatRad = Lat*DEG2RAD; variable LongRad = LongTemp*DEG2RAD; variable LongOriginRad; variable ZoneNumber; ZoneNumber = floor((LongTemp + 180)/6) + 1; if( Lat >= 56.0 && Lat < 64.0 && LongTemp >= 3.0 && LongTemp < 12.0 ) ZoneNumber = 32; endif // Special zones for Svalbard if( Lat >= 72.0 && Lat < 84.0 ) if ( LongTemp >= 0.0 && LongTemp < 9.0 ) ZoneNumber = 31; elseif( LongTemp >= 9.0 && LongTemp < 21.0 ) ZoneNumber = 33; elseif(LongTemp >= 21.0 && LongTemp < 33.0 ) ZoneNumber = 35; elseif(LongTemp >= 33.0 && LongTemp < 42.0 ) ZoneNumber = 37; endif endif LongOrigin = (ZoneNumber - 1)*6 - 180 + 3; //+3 puts origin in middle of zone LongOriginRad = LongOrigin * DEG2RAD; //compute the UTM Zone from the latitude and longitude eccPrimeSquared = (eccSquared)/(1-eccSquared); N = a/sqrt(1-eccSquared*sin(LatRad)*sin(LatRad)); T = tan(LatRad)*tan(LatRad); C = eccPrimeSquared*cos(LatRad)*cos(LatRad); AA = cos(LatRad)*(LongRad-LongOriginRad); M = (1 - eccSquared/4 - 3*eccSquared*eccSquared/64 - 5*eccSquared*eccSquared*eccSquared/256)*LatRad M -= (3*eccSquared/8 + 3*eccSquared*eccSquared/32 + 45*eccSquared*eccSquared*eccSquared/1024)*sin(2*LatRad) M += (15*eccSquared*eccSquared/256 + 45*eccSquared*eccSquared*eccSquared/1024)*sin(4*LatRad) M -= (35*eccSquared*eccSquared*eccSquared/3072)*sin(6*LatRad) M *= a UTMEasting = (k0*N*(AA+(1-T+C)*AA*AA*AA/6+ (5-18*T+T*T+72*C-58*eccPrimeSquared)*AA*AA*AA*AA*AA/120)+ 500000.0); UTMNorthing = (k0*(M+N*tan(LatRad)*(AA*AA/2+(5-T+9*C+4*C*C)*AA*AA*AA*AA/24+ (61-58*T+T*T+600*C-330*eccPrimeSquared)*AA*AA*AA*AA*AA*AA/720))); if(Lat < 0) UTMNorthing += 10000000.0; //10000000 meter offset for southern hemisphere endif gps.UTMEasting = UTMEasting gps.UTMNorthing = UTMNorthing gps.UTMZone = num2str(ZoneNumber)+ UTMLetterDesignator(Lat) End Function/t UTMLetterDesignator( Lat) variable Lat //This routine determines the correct UTM letter designator for the given latitude //returns "Z" if latitude is outside the UTM limits of 84N to 80S //Written by Chuck Gantz- chuck.gantz@globalstar.com string LetterDesignator; if((84 >= Lat) && (Lat >= 72)) LetterDesignator = "X"; elseif((72 > Lat) && (Lat >= 64)) LetterDesignator = "W"; elseif((64 > Lat) && (Lat >= 56)) LetterDesignator = "V"; elseif((56 > Lat) && (Lat >= 48)) LetterDesignator = "U"; elseif((48 > Lat) && (Lat >= 40)) LetterDesignator = "T"; elseif((40 > Lat) && (Lat >= 32)) LetterDesignator = "S"; elseif((32 > Lat) && (Lat >= 24)) LetterDesignator = "R"; elseif((24 > Lat) && (Lat >= 16)) LetterDesignator = "Q"; elseif((16 > Lat) && (Lat >= 8)) LetterDesignator = "P"; elseif(( 8 > Lat) && (Lat >= 0)) LetterDesignator = "N"; elseif(( 0 > Lat) && (Lat >= -8)) LetterDesignator = "M"; elseif((-8> Lat) && (Lat >= -16)) LetterDesignator = "L"; elseif((-16 > Lat) && (Lat >= -24)) LetterDesignator = "K"; elseif((-24 > Lat) && (Lat >= -32)) LetterDesignator = "J"; elseif((-32 > Lat) && (Lat >= -40)) LetterDesignator = "H"; elseif((-40 > Lat) && (Lat >= -48)) LetterDesignator = "G"; elseif((-48 > Lat) && (Lat >= -56)) LetterDesignator = "F"; elseif((-56 > Lat) && (Lat >= -64)) LetterDesignator = "E"; elseif((-64 > Lat) && (Lat >= -72)) LetterDesignator = "D"; elseif((-72 > Lat) && (Lat >= -80)) LetterDesignator = "C"; else LetterDesignator = "Z"; //This is here as an error flag to show that the Latitude is outside the UTM limits endif return LetterDesignator; End Function UTMtoLL(ReferenceEllipsoid, UTMEasting, UTMNorthing, UTMZone, gps) variable referenceEllipsoid,UTMeasting,UTMNorthing string UTMzone struct GPSpos &gps Variable Lat, Long //converts UTM coords to lat/long. Equations from USGS Bulletin 1532 //East Longitudes are positive, West longitudes are negative. //North latitudes are positive, South latitudes are negative //Lat and Long are in decimal degrees. //Written by Chuck Gantz- chuck.gantz@globalstar.com make/o/d/n=(23) EquatorialRadius, SquareOfEccentricity make/o/n=23/T EllipsoidName EquatorialRadius={6377563, 6378160, 6377397, 6377484, 6378206, 6378249, 6377276, 6378166, 6378150, 6378160, 6378137, 6378200, 6378270, 6378388, 6378245, 6377340, 6377304, 6378155, 6378160, 6378165, 6378145, 6378135, 6378137} SquareOfEccentricity={.00667054,.006694542,.006674372,.006674372,.006768658,.006803511,.006637847,.006693422,.006693422,.006694605,.00669438,.006693422,.00672267,.00672267,.006693422,.00667054,.006637847,.006693422,.006694542,.006693422,.006694542,.006694318,.00669438} EllipsoidName={"Airy","Australian National","Bessel 1841","Bessel 1841 (Nambia) ","Clarke 1866","Clarke 1880","Everest","Fischer 1960 (Mercury) ","Fischer 1968","GRS 1967", "GRS 1980", "Helmert 1906","Hough", "international", "Krassovsky", "Modified Airy", "Modified Everest", "Modified Fischer 1960", "South American 1969","WGS 60","WGS 66","WGS-72", "WGS-84"} variable k0 = 0.9996; variable a = EquatorialRadius[ReferenceEllipsoid]; variable eccSquared = SquareOfEccentricity[ReferenceEllipsoid]; variable eccPrimeSquared; variable e1 = (1-sqrt(1-eccSquared))/(1+sqrt(1-eccSquared)); variable N1, T1, C1, R1, D, M; variable LongOrigin; variable mu, phi1, phi1Rad; variable x, y; variable ZoneNumber; string ZoneLetter; variable NorthernHemisphere; //1 for northern hemispher, 0 for southern x = UTMEasting - 500000.0; //remove 500,000 meter offset for longitude y = UTMNorthing; //UTMZone is something like 32P. Zone number is 32, Zone letter is P sscanf UTMZone, "%d%s", ZoneNumber, ZoneLetter if((char2num(ZoneLetter) - char2num("N")) >= 0) NorthernHemisphere = 1;//povariable is in northern hemisphere else NorthernHemisphere = 0;//povariable is in southern hemisphere y -= 10000000.0;//remove 10,000,000 meter offset used for southern hemisphere endif LongOrigin = (ZoneNumber - 1)*6 - 180 + 3; //+3 puts origin in middle of zone eccPrimeSquared = (eccSquared)/(1-eccSquared); M = y / k0; mu = M/(a*(1-eccSquared/4-3*eccSquared*eccSquared/64-5*eccSquared*eccSquared*eccSquared/256)); phi1Rad = mu + (3*e1/2-27*e1*e1*e1/32)*sin(2*mu)+ (21*e1*e1/16-55*e1*e1*e1*e1/32)*sin(4*mu)+(151*e1*e1*e1/96)*sin(6*mu); phi1 = phi1Rad*rad2deg; N1 = a/sqrt(1-eccSquared*sin(phi1Rad)*sin(phi1Rad)); T1 = tan(phi1Rad)*tan(phi1Rad); C1 = eccPrimeSquared*cos(phi1Rad)*cos(phi1Rad); R1 = a*(1-eccSquared)/((1-eccSquared*sin(phi1Rad)*sin(phi1Rad))^1.5); D = x/(N1*k0); Lat = phi1Rad - (N1*tan(phi1Rad)/R1)*(D*D/2-(5+3*T1+10*C1-4*C1*C1-9*eccPrimeSquared)*D*D*D*D/24 +(61+90*T1+298*C1+45*T1*T1-252*eccPrimeSquared-3*C1*C1)*D*D*D*D*D*D/720); Lat = Lat * rad2deg; Long = (D-(1+2*T1+C1)*D*D*D/6+(5-2*C1+28*T1-3*C1*C1+8*eccPrimeSquared+24*T1*T1)*D*D*D*D*D/120)/cos(phi1Rad); Long = LongOrigin + Long * rad2deg; gps.Long = Long gps.Lat = Lat End //Function Uses Google maps to return latitude and longitude of an address // Requires: easyHttp XOP // Geoff Dutton March 5, 2009 Function GeocodeWithGoogle(address, gps) string address struct GPSpos &gps variable lat, long String url, GmapOutput // build a URL for Google maps address = urlencode(Address) Sprintf url, "http://maps.google.com/maps/geo?q=%s&output=csv", address // use easyHttp to contact Google maps, Google maps returns lat, long encoded text easyHttp url GmapOutput = S_getHttp // create a list from returned Google text GmapOutput = ReplaceString(",", GmapOutput, ";") // Google returns 200 if address was found if ( str2num(StringFromList( 0, GmapOutput)) == 200 ) lat = str2num(StringFromList(2, GmapOutput)) long = str2num(StringFromList(3, GmapOutput)) endif gps.Lat = lat gps.long = long end
