A filtered list of all controls in a window, including subwindows
harneit
If you have ever tried to make your functions aware of subwindows, you might have missed a function that returns a list of all controls in a window, regardless of whether they are in the main window or in a subwindow. The function given below is highly configurable (you can filter by match strings and/or control types, recurse through child windows...), please consult the comments in the snippet.
print ControlList("graph0#p1","button","m:*_tab0;r:children")
returns a list of all button
s in the subwindow graph0#p1
or its subwindows (=children), but only if their names end in _tab0
-- a sample output would be graph0#p1 button0_tab0;graph0#p1 button1_tab0;graph0#p1#p0 button0_tab0;
.Here's the full snippet...
strconstant ksCtrlTypes = "Button;CheckBox;PopupMenu;ValDisplay;SetVariable;Chart;" ksCtrlTypes += "Slider;TabControl;GroupBox;TitleBox;ListBox;CustomControl" // function/S ControlList(hostNameStr, typeStr, optionsStr) // returns a complete list of controls in a window or subwindow, selected by type and other options. // // hostNameStr can be a window name like "graph0" or a subwindow spec like "graph0#P0" // // typeStr can be either a literal like "button", "checkbox" etc. // or a number (as string) like "33" that follows a Bit Parameter logic: // button = 1 = 2^0, checkbox = 2 = 2^1, ... chart = 32 = 2^5, etc. (see ksCtrlTypes) // bitwise combinations match more than one type, e.g. 33 = button or chart // the number 4095 = 2^12 - 1 matches any type // // optionsStr = "M:pop*_tab0" matches all controls that start with "pop" and end with "_tab0" // optionsStr = "R:children" returns all controls starting from hostNameStr // optionsStr = "R:full" forces full recursion from the top host // (e.g. from graph0 when called with hostNameStr = "graph0#P0") // you can combine different options by putting them in a list like "M:pop*;R:full" // // the output format is chosen to be convenient for appending each list item to "ControlInfo/W=" // you might want to change this - look for "OUTPUT FORMAT" // function/S ControlList(hostNameStr, typeStr, optionsStr) string hostNameStr, typeStr, optionsStr // 1. convert typeStr to type, quit if that does not work variable type = str2num(typeStr) // if a number is specified, bit-logic is assumed if( numType(type) == numType(NaN) ) // if not a number, typeStr must be literal like "chart" type = 2^WhichListItem(typeStr, ksCtrlTypes, ";", 0, 0) // case-insensitive if( type < 1 ) // WhichListItem returned -1? Then we dont know about this type return "" endif endif // 2. build a list of subwindows to search through string recurseStr = StringByKey("R", optionsStr), swList if( !cmpstr(recurseStr, "full") ) // case insensitive swList = SubWindowList( StringFromList(0, hostNameStr, "#") ) elseif( !cmpstr(recurseStr, "children") ) swList = SubWindowList( hostNameStr ) else swList = hostNameStr endif // 3. get the ControlNameList for each subwindow, filter for types string matchStr = StringByKey("M", optionsStr) string outputList = "", ctrlList, subwin, ctrl variable k, n for( k = 0; k < ItemsInList(swList); k += 1 ) subwin = StringFromList(k, swList) if( WinType(subwin) != 1 && WinType(subwin) != 7 ) // graphs and panels only continue // bypass rest of for(k...) loop endif ctrlList = ControlNameList(subwin, ";", matchStr) // filter by match string for( n = 0; n < ItemsInList(ctrlList); n += 1 ) ctrl = StringFromList(n, ctrlList) if( type & GetControlType(subwin, ctrl) ) // filter by type outputList += subwin + " " + ctrl + ";" // OUTPUT FORMAT for ControlInfo/W=... endif endfor endfor return outputList // RemoveEnding(outputList) if you prefer end // return the type of a control in bit parameter logic (see ControlList above) // if the control is not found, a "1/2" will be returned function GetControlType(winNameStr, ctrlNameStr) string winNameStr, ctrlNameStr ControlInfo/W=$winNameStr $ctrlNameStr return 2^( abs(V_flag) - 1 ) end // return a (recursive) list of all child windows with full host specs function/S SubWindowList(hostNameStr) string hostNameStr string childList = ChildWindowList(hostNameStr), swList = hostNameStr + ";" variable n for( n = 0; n < ItemsInList(childList); n += 1 ) swList += SubWindowList(hostNameStr+"#"+StringFromList(n, childList)) + ";" endfor return RemoveEnding(swList) // necessary to avoid empty items end
