printing Commands to history (similar to the ToCommandLine operation)
ToCommandLine operation sends command text to the command line without executing the command(s).  However, sometimes you want command text to be printed into the history, from within a user  function.  You can use  print for this, but this doesn't appear as an issued command.  For this to happen (such that you can press "up" to scroll between commands) you have to prefix the print with a special character.  This character is different on windows and on Mac.  The following function prints commands to the history, on Mac and Windows.  It works on an English charset, not sure about others.Function cmdToHistory(cmd) // returns 0 if Macintosh, 1 if Windows string cmd String platform= UpperStr(igorinfo(2)) strswitch(platform) case "MACINTOSH": print num2char(-91) + cmd break case "WINDOWS": print num2char(-107)+cmd break endswitch End
