Bernoulli Number generator
s.r.chinn
function fB(nB) // recursive function for Bernoulli Number variable nB // number index argument variable v if(nB==0) return 1 else make/O/D/FREE/N=(nB) wB wB = binomial(nB+1,p)*fB(p) v = -sum(wB)/(nB+1) return v // Bernoulli number value endif end
The second argument, 1, in
zeta(n,1,400)
makes it the Riemann zeta function; the third argument improves the precision for small 'n'.October 2, 2017 at 08:18 am - Permalink
October 5, 2017 at 07:06 am - Permalink
I think the importance of computation speed depends on what the user needs. For computing many Bn at the same time a recursive approach is widely used. As Brent notes (https://arxiv.org/abs/1108.0286v3): "However, this is unsatisfactory if floating-point numbers are used, because the recurrence in numerically unstable." Harvey (http://web.maths.unsw.edu.au/~davidharvey/talks/bernoulli.pdf) gives an interesting approach wherein ONE division operation provides all necessary coefficients for the Bn up to a given order. The hitch is that huge numerators and denominators are required, and the division is best done in base 2. I tested the concept using
APmath
in base 10, and it works!October 5, 2017 at 08:21 am - Permalink
I agree. I was posting more to explore other options.
October 9, 2017 at 06:19 pm - Permalink
