Catmull Rom spline
tony
// Create a spline that passes through a series of x-y points // Catmull E. and Rom R. (1974) A class of local interpolating splines. // In Computer Aided Geometric Design, R.E. Barnhill and R.F. Reisenfeld, Eds. // Academic Press, New York, 1974, pp. 317–326. function CatmullRomSpline(xdata, ydata [,segPoints, alpha]) wave xdata, ydata variable segPoints, alpha if( ParamIsDefault(segPoints) ) segPoints=20 endif if( ParamIsDefault(alpha) ) alpha=0.5 endif variable np=numpnts(ydata) string newXname, newYname newXname=nameofwave(xdata)+"_CR" newYname=nameofwave(ydata)+"_CR" if(exists(newXname)||exists(newYname)) doalert 1, "overwrite existing wave?" if (V_Flag==2) return 0 endif endif make /o/n=0 $newXname /WAVE=CR_x, $newYname /WAVE=CR_y make /free /n=(segPoints) x_out, y_out make /free /n=4 x_in, y_in variable i for(i=0;i<(np-1);i+=1) if (i==0) // first segment // reflect through end points x_in[0]=xdata[0]-(xdata[1]-xdata[0]) x_in[1,3]=xdata[p-1] y_in[0]=ydata[0]-(ydata[1]-ydata[0]) y_in[1,3]=ydata[p-1] elseif(i==(np-2)) // last segment x_in[0,2]=xdata[i-1+p] x_in[3]=xdata[np-1]+(xdata[np-1]-xdata[np-2]) y_in[0,2]=ydata[i-1+p] y_in[3]=ydata[np-1]+(ydata[np-1]-ydata[np-2]) else x_in=xdata[i-1+p] y_in=ydata[i-1+p] endif CatmullRomSegment(x_in, y_in, x_out, y_out, alpha) concatenate /NP {x_out}, CR_x concatenate /NP {y_out}, CR_y endfor // insert end point CR_x[numpnts(CR_x)]={xdata[np-1]} CR_y[numpnts(CR_y)]={ydata[np-1]} end function CatmullRomSegment(w_x, w_y, xout, yout, alpha) wave w_x, w_y // x and y values of four control points wave xout, yout // output waves variable alpha // alpha=0 for standard (uniform) Catmull-Rom spline // alpha=0.5 for centripetal Catmull-Rom spline // alpha=1 for chordal Catmull-Rom spline variable nPoints=numpnts(xout) variable t0, t1, t2, t3 t0=0 t1=sqrt( (w_x[1]-w_x[0])^2 + (w_y[1]-w_y[0])^2 )^alpha + t0 t2=sqrt( (w_x[2]-w_x[1])^2 + (w_y[2]-w_y[1])^2 )^alpha + t1 t3=sqrt( (w_x[3]-w_x[2])^2 + (w_y[3]-w_y[2])^2 )^alpha + t2 make /free/n=(nPoints) w_t,A1x,A1y,A2x,A2y,A3x,A3y,B1x,B1y,B2x,B2y w_t=t1+p/(nPoints)*(t2-t1) A1x=(t1-w_t)/(t1-t0)*w_x[0] + (w_t-t0)/(t1-t0)*w_x[1] A1y=(t1-w_t)/(t1-t0)*w_y[0] + (w_t-t0)/(t1-t0)*w_y[1] A2x=(t2-w_t)/(t2-t1)*w_x[1] + (w_t-t1)/(t2-t1)*w_x[2] A2y=(t2-w_t)/(t2-t1)*w_y[1] + (w_t-t1)/(t2-t1)*w_y[2] A3x=(t3-w_t)/(t3-t2)*w_x[2] + (w_t-t2)/(t3-t2)*w_x[3] A3y=(t3-w_t)/(t3-t2)*w_y[2] + (w_t-t2)/(t3-t2)*w_y[3] B1x=(t2-w_t)/(t2-t0)*A1x + (w_t-t0)/(t2-t0)*A2x B1y=(t2-w_t)/(t2-t0)*A1y + (w_t-t0)/(t2-t0)*A2y B2x=(t3-w_t)/(t3-t1)*A2x + (w_t-t1)/(t3-t1)*A3x B2y=(t3-w_t)/(t3-t1)*A2y + (w_t-t1)/(t3-t1)*A3y xout=(t2-w_t)/(t2-t1)*B1x + (w_t-t1)/(t2-t1)*B2x yout=(t2-w_t)/(t2-t1)*B1y + (w_t-t1)/(t2-t1)*B2y end
