Clone DimLabels from one wave to another
ChrLie
MatrixOP
or Wavestats/PCST
.// takes DimLabels from wL and clones it to w // labels as much as possible in case of varying dimension lengths // optionally one can choose one dimension to be cloned instead of all function CloneDimLabels(wL,w [,dim]) wave wL, w variable dim variable nDim, i, npntsL, npnts, minPnts // run through all four dimensions for(nDim=0; nDim<3; nDim+=1) if(!ParamIsDefault(dim)) // if dim is specified, skip all others if(nDim != dim) continue endif endif // check if a dimension exists in both waves npntsL = DimSize(wL, nDim) npnts = DimSize(w, nDim) if(npntsL > 0 && npnts > 0) // compare dimension size minPnts = min(npntsL, npnts) for(i=0; i<minPnts; i+=1) SetDimLabel nDim, i, $GetDimLabel(wL, nDim, i), w endfor endif endfor return 1 end
