SimpLiFi - Simple line profiles for TEM/STEM images
kpantzas
The SimpLiFi package provides an interface for extracting and analyzing line profiles from TEM/STEM images. This tool is in part a simplified version of the Image Line Profile tool provided in the ImageProcessing package by WaveMetrics ( SimpLiFi does not handle paths - only straight lines - and only greyscale images). It is also in part modified to mimic functionalities of the Line Profile tool available in Gatan's Digital Micrograph:
- A Frame is displayed on the image to show the width over which the profile is drawn
- Two cursors can be displayed on the profile graph to compute the thickness of a feature (e.g. a layer), and also extract the mean image intensity, as well as an average of values that are within 5% of the max and 5% of the min of the profile section between the cursors
- Dashed lines are displayed on the image to show the position of cursors on the profile graph
- The computed values (thickness, average, min, max) can be exported to a Results wave
- The Results wave can be displayed in a Table
This project is still in development and will evolve as my understanding of IGOR programming evolves. Comments and suggestions are welcome.
SimpLiFi - Simple line profiles for TEM/STEM images IGOR.6.30.x
Release File: | QHAADFLineProfile.ipf (26.15 KB) |
Version: | IGOR.6.30.x |
Version Date: | |
OS Compatibility: | Windows |
Release Notes: | First working release of the project |
