Stacked plots / Multiple plots graph
ChrLie
Not extensively tested, but it might be useful for one or the other. To test it:
make/D/O/N=1000 aa, bb, cc, dd setscale/i x, 0, 3*pi, "", aa,bb, cc, dd aa=sin(x) bb=cos(x) cc= tan(x) dd=abs(sin(x))
Then use:
function MakeStackedGraph(yWaveList, xWaveList, nCols, spacing, GraphName, mirror) string yWaveList // semicolon separated list containing wave names to be plotted string xWaveList // semicolon separated list containg corresonding x data; if list items are empty, y-waves will be plotted against x-scaling variable nCols // number of columns within the stacked graph variable spacing // spacing between plots in terms of fraction of total plot area string GraphName // name of the stacked graph variable mirror // mirror axis on = 1, or off = 0 variable nGraphs variable nRows variable nGaps variable yLength variable xLength variable y0, x0, y1, x1 variable i, j, n = 0 string yWave, xWave string yAxisName, xAxisName, yMirrorName, xMirrorName // how many graphs are there and how many rows are required nGraphs = ItemsInList(yWaveList) nRows = ceil(nGraphs / nCols) // calculate length of axis from given spacing nGaps = nCols - 1 xLength = (1 - spacing * nGaps) / nCols nGaps = nRows - 1 yLength = (1 - spacing * nGaps) / nRows // Display empty window; kill if it exists DoWindow/F $GraphName if(V_flag) KillWindow $GraphName endif Display/K=1 /N= $Graphname // append traces for(i=0; i<nRows; i+=1) // reset vertical axis position y0 = 0 x1 = 0 for (j=0; j< nCols; j+=1) // get wave names from lists yWave = StringFromList(n, yWaveList) yAxisName = "yAxis" + num2str(n) xWave = StringFromList(n, xWaveList) xAxisName = "xAxis" + num2str(n) if(strlen(xWave) == 0) // if x-string is empty; plot against wave scaling AppendToGraph/L=$yAxisName /B=$xAxisName $yWave else AppendToGraph/L=$yAxisName /B=$xAxisName $yWave vs $xWave endif // set lower left position of y and x axis ModifyGraph freePos($yAxisName)={y0,kwFraction} ModifyGraph freePos($xAxisName)={x0,kwFraction} // set length of the axis ModifyGraph axisEnab($yAxisName)={y1,(y1+yLength)} ModifyGraph axisEnab($xAxisName)={x1,(x1+xLength)} // do some formatting ModifyGraph tick($yAxisName) = 2, tick($xAxisName) = 2 ModifyGraph btlen($yAxisName) = 4, btlen($xAxisName) = 4 // append mirror axis if(mirror) yMirrorName = "yMirror" + num2str(n) NewFreeAxis/L $yMirrorName ModifyFreeAxis $yMirrorName master = $yAxisName ModifyGraph freePos($yMirrorName) ={(y0+xLength), kwFraction} ModifyGraph axisEnab($yMirrorName) ={y1, (y1+ylength)} ModifyGraph noLabel($yMirrorName)=2 ModifyGraph tick($yMirrorName) = 0, btlen($yMirrorName) = 4 xMirrorName = "xMirror" + num2str(n) NewFreeAxis/B $xMirrorName ModifyFreeAxis $xMirrorName master = $xAxisName ModifyGraph freePos($xMirrorName) ={(x0+yLength), kwFraction} ModifyGraph axisEnab($xMirrorName) ={x1, (x1+xlength)} ModifyGraph noLabel($xMirrorName)=2 ModifyGraph tick($xMirrorName) = 0, btlen($xMirrorName) = 4 endif // shift next starting positions to the right y0 += xLength + spacing x1 += xlength + spacing // increase plot counter n += 1 endfor // shift next starting positions up x0 += yLength + spacing y1 += yLength + spacing endfor return 1 end
and execute e.g.:
MakeStackedGraph("aa;bb;cc;dd;", ";;;;", 2, 0.1, "Multi", 1)
This uses the wave scaling as values for the x-axis. Alternatively use e.g. the following to create X-Y plots:
MakeStackedGraph("aa;bb;cc;dd;", "aa;aa;aa;aa;", 1, 0.05, "Multi", 0)
