Parametric surface generation: execution time comparisons
Function makeMobius(pointsx,pointsy,tmin,tmax) // Igor Example Variable pointsx,pointsy,tmin,tmax Variable i,j,s,arg,ds,tt,dt Make/O/n=(pointsx,pointsy,3) mobius ds=2*pi/(pointsx-1) dt=(tmax-tmin)/(pointsy-1) for(i=0;i<pointsx;i+=1) s=i*ds for(j=0;j<pointsy;j+=1) tt=tmin+j*dt arg=1+cos(s/2)*tt mobius[i][j][0]=cos(s)*arg mobius[i][j][1]=sin(s)*arg mobius[i][j][2]=tt*sin(s/2) endfor endfor End Function makeMobiusP(pointsx, pointsy) variable pointsx, pointsy // x(u,v) = (1 + (v/2)*cos(u/2) ) * cos(u) // y(u,v) = (1 + (v/2)*cos(u/2) ) * sin(u) // z(u,v) = (v/2) * sin(u/2) Make/O/FREE/N=(pointsx,pointsy) wX, wY, wZ setscale/I x, 0, 2*pi,"", wX, wY, wZ // u setscale/I y, -1, 1, "", wX, wY, wZ // v wX = (1+(y/2)*cos(x/2)) * cos(x) // above tt -> y/2 (with pointsy) wY = (1+(y/2)*cos(x/2)) * sin(x) wZ = (y/2)*sin(x/2) Make/O/N=(pointsx, pointsy,21,3) wMobius Concatenate /O {wX, wY, wZ}, wMobius End Function makeMobiusP2(pointsx, pointsy) variable pointsx, pointsy Make/O/N=(pointsx,pointsy,3) wMobius setscale/I x, 0, 2*pi,"", wMobius // u setscale/I y, -1, 1, "", wMobius // v wMobius[][][0] = (1+(y/2)*cos(x/2)) * cos(x) wMobius[][][1] = (1+(y/2)*cos(x/2)) * sin(x) wMobius[][][2] = (y/2)*sin(x/2) End
The timing results (using 10,000 iterations per test) with 51 x-parameter and 53 y-parameter points are:
Mobius: 2571.55 microseconds per iteration MobiusP: 924.64 microseconds per iteration MobiusP2: 745.831 microseconds per iteration
Your mileage may vary.
