    Akima spline interpolation
#pragma rtGlobals=3 // Use modern global access method and strict wave access. // This code was translated into IGOR from the Python code available at // http://www.lfd.uci.edu/~gohlke/code/akima.py.html // Copyright (c) 2007-2015, Christoph Gohlke // Copyright (c) 2007-2015, The Regents of the University of California // Produced at the Laboratory for Fluorescence Dynamics // All rights reserved. // // Redistribution and use in source and binary forms, with or without // modification, are permitted provided that the following conditions are met: // // * Redistributions of source code must retain the above copyright // notice, this list of conditions and the following disclaimer. // * Redistributions in binary form must reproduce the above copyright // notice, this list of conditions and the following disclaimer in the // documentation and/or other materials provided with the distribution. // * Neither the name of the copyright holders nor the names of any // contributors may be used to endorse or promote products derived // from this software without specific prior written permission. // // THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" // AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE // IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE // ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE // LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR // CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF // SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS // INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN // CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) // ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE // POSSIBILITY OF SUCH DAMAGE. //Akima's interpolation method uses a continuously differentiable sub-spline //built from piecewise cubic polynomials. The resultant curve passes through //the given data points and will appear smooth and natural. // //:Author: // `Christoph Gohlke <http://www.lfd.uci.edu/~gohlke/>`_ // //:Organization: // Laboratory for Fluorescence Dynamics, University of California, Irvine // //References //---------- //(1) A new method of interpolation and smooth curve fitting based // on local procedures. Hiroshi Akima, J. ACM, October 1970, 17(4), 589-602. Function akima(x, y, x_new, y_new) // Return interpolated data using Akima's method. // // Parameters // ---------- // x_new : wave // 1D array of monotonically increasing real values. // y : wave // N-D array of real values. y's length along the interpolation // axis must be equal to the length of x. // x_new : wave // New independent variables. // y_new : wave // Wave to receive results. The number of points must be the same as x_new // make/d/n=2 y_new // akima({0, 1, 2}, {0, 0, 1}, {0.5, 1.5}, y_new) // print y_new // y_new[0]= {-0.125,0.375} Wave x, y, x_new, y_new variable n, mm, mmm, mp, mpp, ii, wm duplicate/free x_new, x_i n = numpnts(x) make/d/n=(numpnts(x) - 1)/free dx, dy, m, m1 dx = x[p + 1] - x[p] dy = y[p + 1] - y[p] m = dy / dx mm = 2 * m[0] - m[1] mmm = 2 * mm - m[0] mp = 2 * m[n - 2] - m[n - 3] mpp = 2 * mp - m[n - 2] m1 = m insertpoints 0, 2, m1 m1[0] = mmm m1[1] = mm insertpoints numpnts(m1), 2, m1 m1[numpnts(m1) - 2] = mp m1[numpnts(m1) - 1] = mpp make/d/free/n=(numpnts(m1) - 1) dm dm = abs(m1[p + 1] - m1[p]) duplicate/r=[2, n + 1]/free dm, f1 duplicate/r=[0, n - 1]/free dm, f2 duplicate/free f1, f12 f12 = f1 + f2 duplicate/free f12, ids ids = f12[p] > 1e-9 * wavemax(f12) ? p : -1 duplicate/free/r=[1, n] m1, b b = m1[p + 1] b = ids[p] >= 0 ? (f1[p] * m1[p + 1] + f2[p] * m1[p + 2]) / f12[p]: 0 duplicate/free m, c, d c = (3.0 * m[p] - 2.0 * b[p] - b[p + 1]) / dx[p] d = (b[p] + b[p + 1] - 2.0 * m) / dx ^ 2 duplicate/free x_i, bins bins = binarysearch(x, x_i) bins = min(bins[p], n - 2) duplicate/free/r=[0, numpnts(x_i) - 1] bins, bb duplicate/free x_i, wj wj = x_i - x[bb] duplicate/free bb, d_p, c_p, b_p b_p = b[bb[p]] c_p = c[bb[p]] d_p = d[bb[p]] y_new = ((wj * d_p + c_p) * wj + b_p) * wj + y[bb] End
First, call calcIota to generate interpolation information; then you can interpolate using Akima's spline method with the akima() function.
November 4, 2015 at 07:11 pm - Permalink
