Reorder Waves in Data Folder
// ReorderWavesInDataFolder(dRef, baseName, sortOptions) // Reorders the waves in the data folder specified by dRef so that they are sorted. // // When you iterate through waves in a given data folder, Igor returns the waves // in the order in which they were added to the data folder. Sometimes a procedures // needs the waves to be in a certain order. This achieves that by temporarily moving // the waves out of the original data folder to a temporary data folder and then moving // them back to the original data folder in the desired order. // // All waves in the specified data folder whose names begin with the specified base name are reordered. // Pass "" for baseName to reorder all waves in the data folder. // // See the SortList function for the meaning of the sortOptions parameter. // // Here is an example: // NewDataFolder/O/S root:TestDataFolder // Make/O xWave3, xWave7, xWave1, xWave0, xWave15, xWave11 // Make/O yWave0, yWave7, yWave1, yWave3, yWave15, yWave11 // ReorderWavesInDataFolder(dRef, "xWave", 16) // ReorderWavesInDataFolder(dRef, "yWave", 16) Function ReorderWavesInDataFolder(dRef, baseName, sortOptions) DFREF dRef String baseName Variable sortOptions // As for SortList function String tempDFName = "%tempForReorderWavesInDF%" NewDataFolder /O dRef:$tempDFName DFREF tempDF = dRef:$tempDFName String waveNames = WaveList(baseName+"*", ";", "") String sortedWaveNames = SortList(waveNames, ";", sortOptions) // Move waves to temp data folder Variable numWaves = itemsInList(waveNames) String name Variable i for(i=0; i<numWaves; i+=1) name = StringFromList(i, sortedWaveNames) MoveWave dRef:$name, tempDF endfor // Move waves back to original data folder for(i=0; i<numWaves; i+=1) name = StringFromList(i, sortedWaveNames) MoveWave tempDF:$name, dRef endfor KillDataFolder tempDF End
