SWC dendrite pruner
inchinn
Code to downsample neuronal morphologies generated in SWC format, for example by the simple neurite tracer in FIJI.
Instructions
Load your SWC file as a 7 column wave
Call "Prune(SWC, spacing)"
where SWC is your neurone and spacing is your desired 3D distance between points.
Will generate a new wave called pruned and show you a projection of the two waves.
Instructions
SWC dendrite pruner IGOR.6.30.x-1.0
Release File: | Dendrite Pruner.zip (70.62 KB) |
Version: | IGOR.6.30.x-1.0 |
Version Date: | |
Version Major: | 1 |
Version Patch Level: | 0 |
Release Notes: |
Code to downsample neuronal morphologies generated in SWC format, for example by the simple neurite tracer in FIJI. Instructions Load your SWC file as a 7 column wave Call "Prune(SWC, spacing)" where SWC is your neurone and spacing is your desired 3D distance between points. Will generate a new wave called pruned and show you a projection of the two waves. |
