Autosave
DRDana
1) Save the existing experiment in place
2) Save a copy of the experiment, with a sequence number appended to its name
3) Display a reminder dialog.
Note it doesn't actually do anything until you manually select the command and turn on auto-save, so it's not completely "auto".
More details in the comments. Because it includes the independentModule pragma, this file won't appear on the list of Procedure windows. If you want to experiment with the code, remove that pragma to make it easier to work with the file.
#pragma rtGlobals=1 // Use modern global access method. #pragma Version=1.00 // 2011-3-30 DRD #pragma independentModule = HOBIAutoSave //-------------------------------------------------------------------------- // Implements automatic background saving or copying of the current experiment file. // Places a dynamic auto-save item in the file menu. When auto-save is not already active, // the auto-save command opens a dialog for selecting the period and mode. When it is active, // the text of the menu item shows how much time remains before the next save. // // Mode is either overwrite, meaning each save replaces the existing experiment file, or copy, // meaning a new copy is created each time, or reminder, which just puts up an alert box. // Note that in copy mode, files that are not included in the packed experiment file will NOT be backed up. // In copy mode, each copy of the file has a sequence number appended to its name. // // This creates a data folder that holds just two settings, the mode and the count value used to auto-name // files in backup mode. The period and status of the background task are stored by Igor's background // scheduler. // // David Dana, 2011/3/30 //-------------------------------------------------------------------------- #ifdef WINDOWS Menu "Data", dynamic "-" ASMenuItem(), /Q, ASMenuAction() End Menu #else Menu "File", dynamic "-" ASMenuItem(), /Q, ASMenuAction() End Menu #endif Constant kOverwriteMode = 1 Constant kBackupMode = 2 Constant kRemindMode = 3 StrConstant ASSettingsFolder = "root:Packages:HOBIAutoSave" //-------------------------------------------------------------------------- // Returns a string for the Auto-save menu item. The text of the menu item depends on the status of the // background task. //-------------------------------------------------------------------------- Function/S ASMenuItem() if (ASIsActive()) // If it's active, display the amount of time remaining before the next save variable remaining = ASSecondsRemaining() string remainingStr if (remaining > 60) remaining = round(remaining/60) remainingStr = "in " + num2str(remaining) + " min" else remainingStr = "in " + num2str(round(remaining)) + " sec" endif string menuStr if (ASMode() == kBackupMode) menuStr = CheckMark() + "Auto-Backup " elseif (ASMode() == kRemindMode) menuStr = CheckMark() + "Auto-Remind " else menuStr = CheckMark() + "Auto-Save " endif return menuStr + remainingStr else return "Auto-Save..." endif End Menu //-------------------------------------------------------------------------- //-------------------------------------------------------------------------- // This is called when the menu item is selected. Depending on whether the background task is running, // either stops it or asks the user to set it up //-------------------------------------------------------------------------- Function ASMenuAction() GetLastUserMenuInfo if (ASIsActive()) ASStop() else ASSetup() endif End Function //-------------------------------------------------------------------------- //-------------------------------------------------------------------------- // Stops the background task //-------------------------------------------------------------------------- Function ASStop() CtrlNamedBackground AutoSave, stop End Function //-------------------------------------------------------------------------- //-------------------------------------------------------------------------- // Starts the background task, with the given period in minutes //-------------------------------------------------------------------------- Function ASStart(minutes) variable minutes if (minutes < 1) minutes = 1 endif CtrlNamedBackground AutoSave, proc=ASTask, dialogsOK = 0, burst = 0 CtrlNamedBackground AutoSave, period=minutes*3600 CtrlNamedBackground AutoSave, start=ticks+minutes*3600 End Function //-------------------------------------------------------------------------- //-------------------------------------------------------------------------- // Background task that does the actual work. Taks a WMBackgroundStruct, as required for any named // background task, but doesn't use it. This routine must also return 0; nonzero tells Igor to halt the // taks. //-------------------------------------------------------------------------- Function ASTask(s) STRUCT WMBackgroundStruct &s // required by Igor but unused // First check whether a save is even necessary ExperimentModified // this only works in overwrite mode; saving a copy doesn't change the "modified" status if (v_flag == 0) // the experiment is unmodified; no need to save return 0 endif if (ASMode() == kOverwriteMode) print "Auto-saving " + time() // print in history SaveExperiment elseif (ASMode() == kBackupMode) ASSetBackupCount(ASBackupCount() + 1) string newName = IgorInfo(1) + "_" + Num2Str(ASBackupCount()) print "Auto-saving \"" + newName + "\",", time() // print in history SaveExperiment/C/P=home as newName else ASRemind() endif return 0 End Function //-------------------------------------------------------------------------- //-------------------------------------------------------------------------- // Handles the setup and user input necessary to start auto-save. //-------------------------------------------------------------------------- Function ASSetup() PathInfo home // First check whether the experiment has previously been saved if (v_flag == 0) // the home path doesn't exist; the experiment has never been saved DoAlert 1, "To use auto-save, you must first give the experiment a name and location. Save it now?" if (v_flag != 1) // 1 = yes clicked return 0 endif SaveExperiment // will prompt user for name and location PathInfo home if (v_flag == 0) // still not saved; user must have cancelled DoAlert 0, "Auto-save cancelled." return 0 endif endif // Prepare to get user input CtrlNamedBackground AutoSave, status // Find the current period setting of the task variable period = NumberByKey ("PERIOD", s_info) / 3600 if (period < 1) // not yet initialized period = 10 endif // put the period into a user-readable string, with units. This string should match one of the choices in the popup // menu below, so that the popup will appear with the current setting selected string perStr if (period > 1) perStr = num2str(period) + " minutes" else perStr = num2str(period) + " minute" endif // Make and display a simple dialog with popup menus display the period and mode choices Prompt perStr, "Auto-save Interval", popup "1 minute;2 minutes;5 minutes;10 minutes;30 minutes;60 minutes;120 minutes" variable mode = ASMode() Prompt mode, "Replace, copy, or show reminders?", popup "Replace original with each save;Make new backup copy with each save;Do not save, only show reminders" DoPrompt/HELP="Note that in copy mode, notebooks, procedures and other files that are separate from the experiment file will not be backed up." "Auto-save Settings", perStr, mode if (v_flag == 1) // cancel was clicked; never mind ASStop() return 0 endif ASSetMode(mode) period = str2num(perStr) ASStart(period) // start the task return period End Function //-------------------------------------------------------------------------- //-------------------------------------------------------------------------- // Returns a reference to the data folder containing the auto-save settings. If it doesn't yet exist, creates // it. The actual name of the folder is contained in a string constant defined at the top of the file //-------------------------------------------------------------------------- Function/DF ASSettingsFolder() DFREF dfr = $ASSettingsFolder if (DataFolderRefStatus (dfr) == 0) NewDataFolder/O root:Packages NewDataFolder/O $ASSettingsFolder dfr = $ASSettingsFolder Variable/G dfr:SaveMode = kOverwriteMode Variable/G dfr:BackupCount // Igor will initialize to zero, or leave alone if it already exists endif dfr = $ASSettingsFolder return dfr End Function //-------------------------------------------------------------------------- //-------------------------------------------------------------------------- // Returns the two-character prefix for a checked menu item //-------------------------------------------------------------------------- Function/S Checkmark() return "!" + Num2Char(18) End Function //-------------------------------------------------------------------------- //-------------------------------------------------------------------------- // Returns 1 if the background task is running, 0 if not //-------------------------------------------------------------------------- Function ASIsActive() CtrlNamedBackground AutoSave, status if (stringmatch(s_info, "*RUN:1*")) return 1 else return 0 endif End Function //-------------------------------------------------------------------------- //-------------------------------------------------------------------------- // Returns number of seconds remaining before the background task next runs. Answer is meaningless if // task isn't running (most likely negative) //-------------------------------------------------------------------------- Function ASSecondsRemaining() variable remaining CtrlNamedBackground AutoSave, status remaining = NumberByKey ("NEXT", s_info) - ticks remaining /= 60 return remaining End Function //-------------------------------------------------------------------------- //-------------------------------------------------------------------------- // Returns value of the mode variable stored in the auto-save folder //-------------------------------------------------------------------------- Function ASMode() DFREF dfr = ASSettingsFolder() NVAR mode = dfr:SaveMode return mode End Function //-------------------------------------------------------------------------- //-------------------------------------------------------------------------- // Sets the value of the mode variable stored in the auto-save folder, and returns its new value //-------------------------------------------------------------------------- Function ASSetMode(newmode) variable newMode DFREF dfr = ASSettingsFolder() NVAR mode = dfr:SaveMode mode = newmode return mode End Function //-------------------------------------------------------------------------- //-------------------------------------------------------------------------- // Returns the value of the backup count variable stored in the auto-save folder. This is used for naming // multiple backup files. //-------------------------------------------------------------------------- Function ASBackupCount() DFREF dfr = ASSettingsFolder() NVAR count = dfr:BackupCount return count End Function //-------------------------------------------------------------------------- //-------------------------------------------------------------------------- // Sets the value of the backup count variable stored in the auto-save folder, and returns its new value //-------------------------------------------------------------------------- Function ASSetBackupCount(newCount) variable newcount DFREF dfr = ASSettingsFolder() NVAR count = dfr:BackupCount count = newCount return count End Function //-------------------------------------------------------------------------- //-------------------------------------------------------------------------- // Display a small non-modal reminder window. User can dismiss it and also turn off future reminders //-------------------------------------------------------------------------- Function ASRemind() if (WinType("ASReminderPanel") == 7) DoWindow/F ASReminderPanel else NewPanel /k=1/W=(84,77,366,174)/N=ASReminderPanel as "Reminder" ModifyPanel fixedSize=1 TitleBox title0,pos={47,15},size={184,16},title="Remember to save your work" TitleBox title0,font="Lucida Grande",fSize=13,frame=0 Button OKButton,pos={21,52},size={70,22},title="OK" Button StopButton,pos={109,52},size={150,22},title="Stop Reminders" Button OKButton, proc=ASRemind_OKProc Button StopButton,proc=ASRemind_StopProc endif beep return 0 End Function Function ASRemind_OKProc(ctrlName) : ButtonControl String ctrlName DoWindow/K ASReminderPanel End Function ASRemind_StopProc(ctrlName) : ButtonControl String ctrlName ASStop() DoWindow/K ASReminderPanel End //--------------------------------------------------------------------------
