IgorCL
741
IgorCL is an external operation for Igor Pro that allows you to perform calculations on your computer's CPU or GPU using OpenCL. OpenCL is a software framework that provides a uniform way to perform computation on heterogeneous devices. The authoritative source on OpenCL is the official website, http://www.khronos.org/opencl/, and particularly the OpenCL specification.
Using IgorCL is very different from writing plain Igor code, and requires a very thorough understanding of programming. Ideally you should have experience with low-level languages such a C or C++. You will probably not get much out of IgorCL unless you are a very advanced Igor programmer with knowledge of C.
IgorCL IGOR.6.20.x-1.2
Release File: | IgorCL Release_1.zip (468.6 KB) |
Version: | IGOR.6.20.x-1.2 |
Version Date: | |
Version Major: | 1 |
Version Patch Level: | 2 |
Release Notes: | Fixed error running benchmark experiment. |
