Load All TIFF Files
//  LoadAllTIFFFilesFromFolder(pathName, nameWaveAfterFileName, displayImages)
//  This function loads each TIFF file in a given file folder into Igor.
//  The name of the TIFF file is assumed to end with ".tif".
//  pathName is the name of an Igor symbolic path or "" to get a dialog.
//  If nameWaveAfterFileName is true, the output wave name is the file name less the extension.
//  Otherwise it is something like image0, image1 . . .
//  If displayImages is true, a new image plot is created for each image.
Function LoadAllTIFFFilesFromFolder(pathName, nameWaveAfterFileName, displayImages)
    String pathName             // Name of an Igor symbolic path or "" to get a dialog
    Variable nameWaveAfterFileName
    Variable displayImages          // 1 to display each image in a plot
    if (strlen(pathName) == 0)
        NewPath/O/M="Choose a folder containing TIFFs" LoadIndexedTIFFPath
        if (V_flag != 0)
            return -1               // User cancelled
        pathName = "LoadIndexedTIFFPath"
    String fileName
    Variable index
    index = 0
    do
        fileName = IndexedFile($pathName, index, ".tif")
        if (strlen(fileName) == 0)
            break           // No more files.
        ImageLoad/P=$pathName/T=TIFF/N=image fileName
        if (V_flag > 0)
            String name = StringFromList(0, S_waveNames)
            Wave w = $name
            if (nameWaveAfterFileName)
                String desiredName = S_fileName     // S_fileName is set by ImageLoad
                desiredName = ParseFilePath(3, S_fileName, ":", 0, 0)   // Remove extension
                if (Exists(desiredName) != 0)
                    desiredName =  UniqueName(desiredName, 1, 0)
                Rename w, $desiredName
            if (displayImages)
                NewImage w
        index += 1
    while (1)
