Dependency Analyzer
RGerkin
This package will allow you to determine which Igor procedure files require which other Igor procedure files to operate. You can select any subsets of your loaded procedure files as "callers" and "callees" and get a graphical display of dependencies. It also shows you which functions in procedure file A call functions in procedure file B. This is useful for identifying which sets of procedure files must go together, and for identifying cyclic dependencies that you may want to avoid.
Project CVS: | http://svn.igorexchange.com/viewvc/packages/DependencyAnalyzer |
Dependency Analyzer IGOR.6.00.x-1.0.1
Release File: | Dependency_Analyzer_1.0.1.zip (8.36 KB) |
Version: | IGOR.6.00.x-1.0.1 |
Version Date: | |
Version Major: | 1 |
Version Patch Level: | 1 |
Release Notes: |
-- Added help buttons and organized help file. -- Added the dependency stack. -- Added the ability to quickly reverse dependency lists. -- Fixed several bugs with the display of small listboxes. -- Function calls that appear on lines that begin with a comment mark are no longer included as "hits". -- A function whose names contain the name of another function (e.g. GreatMyFunc and MyFunc) is no longer includes as a "hit" when searching for that other function. |
