Word Wrap Control Text
aclight
This function returns a string that adds line breaks (\r) to a string of text such that when the text is displayed in a TitleBox control on a panel, the text will fit within the boundaries of a GroupBox control on the same panel.
The following are included with this download:
- Igor Pro procedure file
- Igor Pro help file
- Igor Pro experiment file with example use cases and a demo of the utility
Project License: | http://www.opensource.org/licenses/mit-license.php |
Project Screenshots: | http://www.igorexchange.com/node/48 |
Project CVS: | http://svn.igorexchange.com/viewvc/packages/ACL_WordWrapControlText/trunk/ |
ACL_WordWrapControlText IGOR.6.02.x-1.1
Release File: | ACL_WordWrapControlText-IGOR.6.02.x-1.1.zip (119.44 KB) |
Version: | IGOR.6.02.x-1.1 |
Version Date: | |
Version Major: | 1 |
Version Patch Level: | 1 |
Release Notes: |
This is a bug fix release that fixes the following issues:
Note that because of the fix in #503, Igor version 6.02 or greater is now required. |
