List of fitting functions for a menu
Function/S NewGF_FitFuncList() string theList="", UserFuncs, XFuncs string options = "KIND:10" options += ",SUBTYPE:FitFunc" options += ",NINDVARS:1" UserFuncs = FunctionList("*", ";",options) UserFuncs = RemoveFromList("GFFitFuncTemplate", UserFuncs) UserFuncs = RemoveFromList("GFFitAllAtOnceTemplate", UserFuncs) UserFuncs = RemoveFromList("NewGlblFitFunc", UserFuncs) UserFuncs = RemoveFromList("NewGlblFitFuncAllAtOnce", UserFuncs) UserFuncs = RemoveFromList("GlobalFitFunc", UserFuncs) UserFuncs = RemoveFromList("GlobalFitAllAtOnce", UserFuncs) XFuncs = FunctionList("*", ";", "KIND:12") if (strlen(UserFuncs) > 0) theList += "\\M1( User-defined functions:;" theList += UserFuncs endif if (strlen(XFuncs) > 0) theList += "\\M1( External Functions:;" theList += XFuncs endif if (strlen(theList) == 0) theList = "\\M1(No Fit Functions" endif return theList end
This function is used in the Global Fit package to present a menu of candidate fit functions.
It includes gray items that separately label user-defined functions and XFUNC fitting functions.
Among other things, it filters out user-defined functions lacking the FitFunc subtype keyword.
The incremental building of options at the top of the function is partly a
leftover from when Global Fit had a checkbox that allowed you to optionally
list only functions with the FitFunc subtype. Note that XFuncs don't have
subtypes, so it's impossible to filter out non-fit XFuncs that have the
same signature as a fitting function.
